Old 12-18-2013, 11:17 AM   #1
Nicolas0esp1
Nicolas0esp1's Avatar
Drives: Stock Scion FRS
Arrow Whats The Best Way To Get That Wide Look?
I love my scion FRS but I want to make it look wide and mean. I love the wide boy kit from Greddy but I can really afford that and if i could I would rather get the turbo kit... I was thinking maybe spacers but are spacers bad for your car? Do they effect the performance good or bad? and Which ones should i get to try to make my car look super wide. I was also thinking in new wide rims but that could also be expensive so I was think of buying some and then selling mine. I like the three spokes or support ones... what size should I get if I want it to look wide. I might get a raise in the future so Ill be adding a lot more stuff. THX PS: IK this is not for this tread but i saw this and was wondering wat Exhaust is that (last Pic)
Nicolas0esp1 is offline   Reply With Quote
Old 12-18-2013, 11:51 AM   #2
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
BTW I have 2 set of Ichiba spacers for sale if you were interested.
2 X ICHIBA V2 15mm Spacer
2 X ICHIBA V2 20mm Spacer
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following User Says Thank You to Figo For This Useful Post:
UltraMarine86 (12-19-2013)
Old 12-19-2013, 04:35 AM   #3
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
Wide rims n tires...... 0.o??
MaXimus is offline   Reply With Quote
Old 12-19-2013, 08:39 AM   #4
frslee
Just drive it
Drives: 13' FR-S
You need money.
frslee is offline   Reply With Quote
The Following 4 Users Say Thank You to frslee For This Useful Post:
BlueDubbinTDI (12-19-2013), G-Man (12-19-2013), sprintertrueno86 (12-19-2013), suaveflooder (12-19-2013)
Old 12-19-2013, 10:09 AM   #5
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
Id say lowering the car is the best way to make it look wider aside from actually buying a widebody kit.
Anomie is offline   Reply With Quote
The Following User Says Thank You to Anomie For This Useful Post:
Rayme (12-19-2013)
Old 12-19-2013, 10:13 AM   #6
juanam0909
Drives: scion fr-s
i always reomend cut your fenders and just make a rocket bunny kit out of cardboard and then put 24s or 26s with spinners and maybe write down LFA on the sides and put lexus badges with a nascar logo on your window.
juanam0909 is offline   Reply With Quote
The Following 2 Users Say Thank You to juanam0909 For This Useful Post:
jhx741 (10-08-2014), stock (12-23-2013)
Old 12-19-2013, 10:18 AM   #7
xbiker
Erect Member
Drives: 2013 Asphalt FRS
Eat more donuts?
2013 Asphalt FRS
2000 MR2 Spyder, turbo, hard top, 6sp
2012 Falcon 4-Stroke, ultralight powered parachute
2014 Husqvarna lawn tractor 46" cut, mulching kit
xbiker is offline   Reply With Quote
Old 12-19-2013, 11:31 AM   #8
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
When I did the vinyl in the center of my trunk, it tricks the eye into looking much wider and more "squatty" from the back. Lower def helps. As does getting rid of the rc car antenna, I recommend @PERRIN
Wheel spacers with stockers will help.
Wider wheels if you have the money. Or just throw some meaty 235 wide rubbers on stock wheels.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 12-19-2013, 01:29 PM   #9
djdnz
1337
Drives: 2013 BRZ WRB S/C
Lower it and get wheels with better offset.
djdnz is offline   Reply With Quote
Old 12-19-2013, 01:36 PM   #10
protpibe
protpibe's Avatar
That exhaust is Toms I believe.
That "wide" look done properly will be expensive. You'll want 8 or 9 inch wide wheels with a proper offset and tires, plus lowering springs or coil overs. I would estimate $2 grand installed if you get it done on the cheap. Less if you go for used parts.
As for spacers, they are obviously much cheaper but I don't think you'll achieve the look you want. There's nothing wrong with spacers, I've been running 1" wide spacers on my truck for 2 years without any issues. If you do go this route, make sure you get a decent quality set and make sure they're torqued down properly and you use loctite on the studs.
Old 12-19-2013, 03:26 PM   #11
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
and wider wheels... add cambers to tuck them in, unless you are a fan of mexiflush.
Seriously, OP.. that kind of car is only for shows. I hope you are not selling your car in a few months because of the shitty handling.
hanabie is offline   Reply With Quote
Old 12-19-2013, 03:32 PM   #12
FunCon5
FunCon5's Avatar
To make your car look WIDE, you will need wider wheels, wider tires, and suspension parts. Coilovers, some sort of camber adjustment, and possibly a roll &/or pull of the fenders.
It can be done, but takes Money to be done right. There are many examples on this forum. I'd suggest looking through wheel and tire section and the Members car Journals section.
Good Luck!
FunCon5 is offline   Reply With Quote
Old 12-19-2013, 04:54 PM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
dropping the car effectively change the height:width ratio, so it will look wider. Cheapest way.
Rayme is offline   Reply With Quote
looks good, spacers, wheels, wide body, widebody
Whats the most fun you've had with your FRS? Turbo_FRS Scion FR-S / Toyota 86 GT86 General Forum 43 10-13-2013 11:30 AM
whats going on here Huehuecoyotl Scion FR-S / Toyota 86 GT86 General Forum 0 04-15-2013 07:45 PM
For those that have them, whats the MPG? MXRider BRZ First-Gen (2012+) — General Topics 140 07-10-2012 12:17 AM
