| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: '13 Black Subaru BRZ Limited
Car cover recommendations
I'm deploying for 6 months and I am putting my car in a 10x20 car storage unit. I would like to put a car cover over her to protect the paint. I was looking at the cover from Subaru (~$100) designed for the car but I was thinking there may be something out there that is better and cheaper, or slighlty more expensive but better.
Anyone using the Subaru cover or have an recommendations? |
Drives: 2013BRZ Premium St Silver Metallic
BRZilla
Drives: '13 WRB BRZ Limited MT
http://www.covercraft.com/carcovers/...r_fabrics.html
Here's the comparison guide for covercraft car covers. I bought the Noah through autoanything.com (much cheaper than manufacturers website) but, as a heads up, it's not supposed to be here until mid January, i don't know how a wait like that would fit into your schedule, & if the wait is specific to that cover, that website, or a combination of things Last edited by mjh712; 12-17-2013 at 03:03 PM. Reason: clarity |
Drives: 1985 P-Type
Make sure the car is clean when the cover is put on. And remove periodically to keep it clean. Otherwise the cover can shift and grind dirt into the paint. No bueno!
I'm no cover expert but the factory accessory one is nice. I like mine.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
Drives: 2014 DGM BRZ MT
Don't do it.
Thanks for the info guys but I just talked to my detailer and he said since the car will be inside don't use a cover at all. It just scratches the paint and grinds dirt into the paint.
| The Following User Says Thank You to Bg8780 For This Useful Post: | Pizzman (12-18-2013) |
Crap another obsession.
Drives: 2013 BRZ Limited
Yup! let the dust build, and clear your head when you return with some tunes (and some beers) and a well deserved wash!!!!
Then DRIVE mofo DRIVE! Maybe a nice coat of wax before storage? Last edited by Pizzman; 12-18-2013 at 04:11 PM. Reason: personally a beer too:) |
| The Following User Says Thank You to Pizzman For This Useful Post: | Bg8780 (12-19-2013) |
#9 | |
Then Tom's tailights and headers
#10 |
Drives: 13' DGM Built FBM BRZ
www.carid.com some covers are protected inside.
The dealer i bought my car from recommended not to buy their company car cover because it scratches. Salesman told me whispering lol |
#11 |
Drives: Silica BRZ 6MT
I have the xtreme cover from ebay. It's light enough to just keep the dust off but not heavy enough to rub or grind. I would avoid using any old blankets or comforters, they can collect moisture, bad bad bad for paint.
Honestly if the door to the storage unit isn't being opened & closed (think two car garage with double door) then the cover shouldn't be able to move and grind dirt into the paint *2 cents* |
#12 |
A excerpt from the California Car Cover Company:
Plushweave "Our Plushweave car cover is the only true 100% cotton car cover you will find. Other manufacturers carry a poly-cotton material that is not nearly as soft or breathable. Made of 100% cotton fabric, the Plushweave cover has an added pure cotton flannel lining for paint pampering protection. Its ultra dense construction does a superior job of cushioning against scratches and dings. Perfect for both indoor and fair weather use; it does an excellent job against sun, dew, pollutants and is treated with 3M Scotchgard for light water repellency. The special construction allows the fabric to remain breathable which aids in air-drying and heat reduction to keep your vehicle cooler. Each cover is tailor-made to your exact needs and guaranteed to never scratch. Not recommended for extended outdoor storage. 2-year limited warranty. Our soft, flannel lined Plushweave material is also available for motorcycle applications. Available in Grey, Tan or Black. Made in the U.S.A."Note: If you follow the California Car Cover instructions describing how the cover is to be installed and removed, you shouldn't have any problems with scratches, etc. It will all depend if you see the value of this product and how 'particular' you are. The 'Plushweave' is used a lot by classic car owners. I use this one for my BRZ. |
#13 |
I would like to see the "detailer" say that to a high-end classic car owner. There are all kinds of "detailers" out there and this one that you mention is not the best.
#14 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
OP: If the area where you store your car is very dirty and has a lot of dust (from sand), I suggest cleaning up the area (vacuum, wet clean, vacuum again) and then get a LOOSE fitting freshly cleaned/laundered car cover that is anchored down at multiple points so it doesn't shift (think of pulling a tight tarp over a tent). If the area where you store the car has very little dust, you can go with just a loose fitting cover that's anchored down. Ideally, you want to store her in a climate and dust controlled environment but that is expen$ive. I hate form fitting covers - as they build up dust on them, getting them off without scratching something can be very precarious.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
| Hid i d recommendations? | Vincenttam | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 11-06-2013 01:26 AM |
| PDR Recommendations in NY or CT | TommyFive | NY / NJ / CT / PA | 6 | 09-10-2013 03:48 PM |
| Wheel recommendations? | cncnjn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-09-2013 06:30 PM |
| The cover store car cover for sale. | FRSfan111 | Northwest | 2 | 06-21-2013 04:49 PM |
| painting lip kit..any recommendations? | ft86me | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 06-10-2013 07:30 PM |
