Drives: Asphalt grey, manual Fr-S
Is there a way to wire winjet leds to turn on with a switch?
I have my drl disabled bc i have the led drls from factory. When i install the winjet headlights is there a way to wire the leds in the head lights to turn on with a switch instead of the drl?
What factory LED DRLs?
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
Flip on the high beams? See the ft86speedfactory video for example.
Will that work with an hid kit?
I think he's talking about these:
You can wire them to turn on with the headlights, as for the dimming. You need to cut a wire or disconnect it. I forgot which one it is.
#9 | |
Drives: TRD Ultramarine '13
Then as far as not dimming them goes, if you're talking about the fog light LED strips, then you have to wire them up to a 12 V ignition wire, and if you're talking about the Winjet LED strip, then you also need to find a way to disconnect them and wire them separately to a 12 V ignition wire that's always providing constant power. Right now, they're probably hooked up to a wire that is connected to the headlight stalk inside the car and lower the power when you switch on the low beams. You need to disconnect that. Either that, or just flip on the high beams, that'll give your DRL's and the Winjet LED's full brightness, and isn't a problem unless your headlights also have legit high beams that are going to blind everyone else, but I'm pretty sure the Winjet's with the HID kits don't have true high beams anyway. |
#10 | |
| The Following User Says Thank You to Frs32907 For This Useful Post: | kALMIGHTY (12-16-2013) |
#11 | |
Drives: The silvertrooper 10 series
There should not be any dimming as there are both LED and take very little current to power them up. Hope this helps |
#12 | |
#13 |
Unless you can get a wiring diagram or something from the manufacturer or the seller, you'll need a multimeter and check each of the wires in the headlight to see which one reads 12V when you turn on the LEDs. Either that, or open it up to see which wire goes to the LEDs, but I'm not sure if there's only one wire going to the LEDs or not, but if there is, that would make your life really easy.
#14 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
The red and black wire are for the led and high beam actuator.. The grey and black are for the low beam
| FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! | Diode Dynamics | Interior Parts (Incl. Lighting) | 158 | 08-08-2018 06:52 PM |
| Do Switch Back LEDS Work On The BRZ ? | PhreshhWun | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 08-01-2013 07:14 PM |
| How to replace turn signals with switch backs and its relay switch. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-30-2013 11:42 PM |
| Switch Back LEDs for BRZ | DNAPoPo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-07-2013 08:11 PM |
| Stereo ignition switch wire | bebopblues | Electronics | Audio | NAV | Infotainment | 0 | 11-04-2012 08:58 PM |
