Drives: 14 FRS Whiteout
Removing centre console plaque
Soon I bought a plague from yospeed. In my excitement I immediately rip off the 3m adhesive to stick it on. Now the more I look at it the more I don't like it. What is the easiest way to remove it without me scratching the the surrounding? The adhesive feel very strong.
Drives: 2013 MT FRS, 2002 MR2
Adhesive removers and a little (little!) heat always worked on the exterior for me. Unfortunately the in interior is a mystery to me. When I debadged my car I used adhesive remover for bandages and floss.
Using a heat gun on interior pieces don't seem like a good idea... Seems like it will burn easily... There must be someone here that change their plaque?
Drives: Neptune GR86
Plastic trim/panel removers would be your best bet. I would advise against the heat gun. It will very easily cause the plastic to have a "shiny" look if left too long in one spot.
http://yospeed.com/scion-fr-s-subaru...onsole-plaque/ This is the one I got in brush aluminum 86 logo. On closer inspection the plaque was scratch in many places on the face. And the quality isn't thT good though on par with what I would expect for $20. Biggest problem is that now I have too much silver in the interior. Maybe I will like it more if I black out the whole interior and just leave the plaque brush aluminum. But once I do that I might change my mind and want a black plaque. Either I need to know this thing isn't stuck on there permanently |
Drives: Raven Fr-s
Ah
Might I suggest http://www.ft86club.com/forums/showthread.php?t=45423 And if you replace it you can just pry it out with anything because scratching it wont be an issue because you'll replace it.
#8 | |
It's not scratching the plaque I'm worry about. Is pretty scratch already. I'm worry about scratching the vinyl material around the plaque. I try a flat head screwdriver could dig in far enough to pry it out and will definitely scratch up the the surrounding area if I try hard enough. I will pick up some panel remover to try but it seems like the plastic none marring ones won't be strong enough? |
Wrap a flat head or small pry bar in a towel first if you don't think a plastic tool is strong enough.
#11 |
Drives: Scion FR-S
My vote is for heat gun and a plastic prying tool. Don't over heat the area, just put it on the top of the plaque. You might be able to put some googone in there, but putting a chemical in there against the trim may cause issues, so it's your call.
#12 |
Thanks guy. The plaque doesn't seem so bad after a few days. Shall see what I feel after I. Lack out the interior. Thanks for all the suggestion!
| Centre console assembly problem | Muskokan | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-20-2013 06:58 PM |
| AUDM/JDM Padded Door and Centre Console Kneepads | Sutty | Interior Parts (Incl. Lighting) | 11 | 04-04-2013 04:01 PM |
| Sutty's Centre Console Armrest | Sutty | Interior Parts (Incl. Lighting) | 45 | 03-05-2013 12:21 PM |
| 86 Center Console Plaque | 86_ZN6 | Cosmetic Modification (Interior/Exterior/Lighting) | 51 | 11-26-2012 06:54 PM |
