Old 12-10-2013, 03:43 AM   #1
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Window condensation
Well winter is here, and with the colder temperatures I noticed I get a fair amount of condensation on the inside of my windshield (after being parked for 4+ hours). It seems like more then "normal" and is enough to turn to small drops of water that then leak down my windshield. All this condensation has made keeping my windows clean a pain.
My last car was an Audi A6 and I never saw even a little condensation. Maybe I'm just spoiled? Anyone else experience this?
headlikeahole is offline   Reply With Quote
Old 12-10-2013, 06:15 AM   #2
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
I have yet to have this problem but my windows fog up a whole lot while I am in the car and I have to constantly run the defrosters. Very annoying when I'm very hot from the heater already but the fog doesn't stop. Only happens when it's cold outside. I mean this used to happen to me after the gym in other cars but never just normally.
SoCal909 is offline   Reply With Quote
Old 12-10-2013, 09:12 AM   #3
NOHOME
Drives: RAVEN
Small amounts of snow that get tracked in to the car add up to a lot of water vapour trapped in a small volume.
So, yeah, I get the same thing.
NOHOME is offline   Reply With Quote
Old 12-10-2013, 09:32 AM   #4
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
I have had this in every Japanese car I have owned. It is much more common in them than in the American and German cars that I owned over the years. My son complains about this in his new FR-S.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 12-10-2013, 09:42 AM   #5
Muskokan
Drives: white Sport-tech
Happen to have it inside? I never have much but when I took it down to the parkade at my work it sweat worse than Rob Ford after the latest accusations.
Muskokan is offline   Reply With Quote
Old 12-10-2013, 02:43 PM   #6
Captain Stall
OK, here we g...oh, wait
Captain Stall's Avatar
Drives: '13 Hot Lava 6M
I've had it happen a couple of times now. It wasn't uncommon in my '98 Acura EL either. I keep my cars outside.
Captain Stall is offline   Reply With Quote
Old 12-10-2013, 03:42 PM   #7
headlikeahole
I do park indoors but it's outside on a cold day that the inside get condensation.
Old 12-10-2013, 03:55 PM   #8
FerraraZ
Drives: 13' FR-S Firestorm Red
I can say I have this. Here is a picture of what it looks like for me:
http://imgur.com/QViTxEM
FerraraZ is offline   Reply With Quote
Old 12-10-2013, 05:11 PM   #9
headlikeahole
That's it for sure. Only when I get in the car sometimes it's the entire windshield.
That picture tells me it's moisture coming in from the vent in the dash. Maybe changing the vent to recirculate before parking the car would help.
Old 12-10-2013, 05:22 PM   #10
Krazy
Krazy's Avatar
Drives: FR-s
Have you guys had it on the bottom half of the rear windshield? I thought it was from the outside until I noticed it and touched it.
Krazy is offline   Reply With Quote
Old 12-10-2013, 05:47 PM   #11
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
Get some of this to remove the current moisture in your car. every couple of days change it if it has absorbed moisture. If after a month you still have condensation you may have a leak. If you live in a dry climate with very little rain you may not notice it as much. I had the same problem with a Carrera and it ended up being that on the last detailing job they had a new kid doing it and he did not let the car dry out with the windows open.
http://www.damprid.com/
Rio is offline   Reply With Quote
Old 12-10-2013, 05:49 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Two things that will help:
1) If your A/C is on, turn it off and blow non-A/C air for a few seconds before turning off the car.
2) Run the header + A/C from time to time on highest settings.
-alex
Old 12-10-2013, 05:55 PM   #13
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
That happens on my Tacoma when it's last left on the defroster, right in the bottom middle. The extra heat that is coming from the vents after it's turned off will add the extra moisture.
Old 12-10-2013, 05:55 PM   #14
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Wow. That's strange.
I live in the Pacific Northwest, where it rains 364 days out of the year, and I've never seen that in any of my cars. I'm going to guess that it's because I run my heater almost constantly. I'm always cold. In the summer, if its not raining, I usually have my windows down. Sometimes on sunny days, even now, I run my heater full bore and roll my windows down. :-)
NWFRS is offline   Reply With Quote
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
BRZ DRL Condensation Perihelion Issues | Warranty | Recalls / TSB 8 03-02-2016 12:23 PM
DRL condensation. Superhatch BRZ First-Gen (2012+) — General Topics 16 10-20-2013 02:13 PM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
LED DRL Condensation ngabdala Issues | Warranty | Recalls / TSB 3 11-22-2012 09:38 AM
