Drives: 2005 Toyota Camry
REVIEW | Raceseng UPM (Universal Plate Mount)
I bought the @Raceseng UPM (Universal Plate Mount) last week, after realizing that this had came out recently. I previously purchased their Tug View tow hook/GoPro mount, so the tug shaft that is needed for install was already on the car.
The details on the product can be found on the Raceseng website, here's my install pics: ![]() ![]() ![]() ![]() ![]() ![]() Some thoughts:
UPM: http://www.raceseng.com/upm-universal-plate-mount UPM w/ tug shaft: http://www.raceseng.com/upm-universa...r-s-subaru-brz -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Ammunition (12-10-2013) |
Coffee Snob
Drives: '14 SWP BRZ Limited
This is great, have you noticed anything since install? I'm considering buying this.
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
@Raceseng if you could integrate a GoPro mount somehow on this thing I would buy it to replace my GrimmSpeed
#4 | |
Drives: 2014 Ultramarine FR-S
http://www.raceseng.com/tug-view-tow...r-s-subaru-brz |
| The Following User Says Thank You to NLSP For This Useful Post: | cdo221 (03-20-2014) |
I mean, a license plate relocator that also can do a GoPro at the same time .. it looks like you have to swap remove the license plate for the GoPro mount to work in this case. Or did I get it wrong, GoPro can still go mount on with the license plate on..?? haha I'm confused
#6 | |
I got this UPM because it gives me a quick way to swap out to the GoPro mount: http://www.ft86club.com/forums/showthread.php?t=53205 -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | cdo221 (03-21-2014) |
#7 | |
http://www.raceseng.com/upm-universal-plate-mount http://www.raceseng.com/tug-view-tow...r-s-subaru-brz I would essentially be able to do a quick swap between 'license plate' and 'tow hook + GoPro' mode, say in a parking lot or something? I assume you need to remove the license plate itself off the UPM before the UPM can be removed? At least that's how the grimm speed works, removal of the license plate off the plate holder first, then removal of the plate holder, then the shaft that goes into the bumper. |
#8 | |
Once you've set the GoPro mount and the license plate mount orientation properly, every time you remove/install the different mounts you will end up at the proper position for either GoPro or the license plate. The Raceseng mount allows you to twist the entire plate holder (with plate) off, and you won't lose the position you set. This is assuming you installed the shaft with Loctite as the instructions mandate. So far I've changed my plates/GoPro mount about 10 times, it gets easier and easier to do. -alex |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
| Raceseng | Tug View - Tow Hook + Go Pro Mount | Raceseng | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-27-2013 01:47 PM |
| *Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* | 86SPEED | Exterior Parts - The Rest | 2 | 08-20-2013 01:37 AM |
| Raceseng | Tug View - Tow Hook + Go Pro Mount | Raceseng | Tracking / Autocross / HPDE / Drifting | 0 | 08-14-2013 03:52 PM |
| DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount | PMok | DIY (Do-It-Yourself) Guides | 2 | 06-11-2013 10:58 AM |
