Old 12-06-2013, 08:59 AM   #1
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Is it worth swapping out just speakers?
I have been asking a lot of audio-related questions here without getting a lot of answers (many thanks to those who have answered!), so I'll keep this brief. Is it worth swapping out the stock speakers without swapping or adding anything else other than the head unit and a sub in the trunk? So no changing wiring, no adding an amp other than for the sub, and no changing crossovers. Is that worth it for someone that isn't an audiophile but just wants the sound to be better without spending a shit-ton of money?
Prog is offline   Reply With Quote
Old 12-06-2013, 09:38 AM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Since sound is hugely subjective, it depends. What exactly do you mean by better? Where is the stock system lacking for you? What do you want to improve?
Old 12-06-2013, 03:31 PM   #3
Prog
Prog's Avatar
I wish I could explain, but I can't. I know it needs bass, which I'm taking care of, but I don't have the audio knowledge to describe what's missing. I came out of a car with a Boston Acoustics system that was really good stock, and the BRZ just pales in comparison. I know one thing is lack the bass, but that's it. I just want it to sound better. Not the best, just better.
Old 12-06-2013, 03:43 PM   #4
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
You'll be underdriving the good aftermarket speakers most likely, though, so that will be a problem as you're more likely to accidentally hit cutoff that way (perfectly good way to blow speakers) b/c of the increased demand.
It's okay to go with them as a starting point as long as you plan to then upgrade the HU soon after, or better yet, plan to amp them soon after.
^GT5 Replay Photo Mode^
Old 12-06-2013, 04:55 PM   #5
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
If you're going to amp the sub you might as well just amplify the stock speakers as well with a 4 or 5 channel amp.
the new guy is offline   Reply With Quote
The Following User Says Thank You to the new guy For This Useful Post:
SirBrass (12-06-2013)
Old 12-07-2013, 09:32 PM   #6
Prog
Prog's Avatar
I already have an aftermarket head unit. What does that change?
Old 12-07-2013, 09:33 PM   #7
Prog
Prog's Avatar
It's an all-in-one sub with built-in amp. I don't plan on buying another amp.
Old 12-07-2013, 10:14 PM   #8
Mo707
Mo707's Avatar
I think theres two amps. one for your subs and one for your speakers.
Mo707 is offline   Reply With Quote
Old 12-07-2013, 10:41 PM   #9
Prog
Prog's Avatar
There's a stock amp in the car, and there's an amp built into my aftermarket subwoofer. Any speakers I swap out would be connected to the stock amp and/or the head unit, with no aftermarket amps involved other than for the sub.
Old 12-07-2013, 10:59 PM   #10
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
If you're just looking for marginally better sound, I'd suggest replacing the stock door speakers. They're the ones run off the amp, and deaden the doors while you're swapping out the speakers. If you're happy after that, then no need to upgrade the other speakers.
kmbkk is offline   Reply With Quote
Old 12-07-2013, 11:07 PM   #11
Prog
Prog's Avatar
That's really exactly what I was hoping to do. After I installed my sub, I sat in the car and tried to figure out exactly what was wrong with the stock speakers. The doors produce a really...bad bass? It's just not very clear, if you can describe bass like that. I think people that know what they're talking about when it comes to audio call this "muddiness," but I'm not sure. I'd really just like to drop some better speakers in there to clear that up, but I don't know if that'll help. I'm assuming I'd need to put some mid-bass drivers in the doors, but please correct me if I'm wrong.
(And Dynamat is on my Christmas list.)
Old 12-07-2013, 11:23 PM   #12
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Yes, mid-bass drivers. Deaden and seal the doors and I'm sure you'll be happy with that.
Old 12-08-2013, 12:05 AM   #13
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
I agree with the last few posts. You should get a much better sound by simply replacing the door speakers. I did this in my old truck without changing the wiring or adding an amp (I had an aftermarket head unit also) and it was a huge improvement. Good upgrade on the cheap for good enough sound in my opinion. I'll end up doing exactly this in the 86 eventually.
fatherfork is offline   Reply With Quote
Old 12-08-2013, 12:25 AM   #14
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I will qualify all my responses with the fact I'm doing a complete install in my car. So, I won't be doing just the above recommendation.
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 04:31 PM
Swapping OEM FRS Spoiler for 5 Axis CamryDS Cosmetic Modification (Interior/Exterior/Lighting) 4 10-30-2013 01:59 AM
Swapping springs need HELP! SleekMachine Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 07-17-2013 04:05 PM
Buying and swapping brz Bumper for frs rhood168 Cosmetic Modification (Interior/Exterior/Lighting) 1 05-12-2013 01:11 AM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
