Old 12-03-2013, 09:12 PM   #1
LazerBrZ
LazerBrZ's Avatar
Drives: Silver Limited BRZ
Amp and subwoofer with stock HU (BRZ)
Ok so first off I tried Google extensivly, but there is a lot of conflicting info out there. So here it is:
I have a rockford fosgate amp and RF 10" sub that I want to hook up to the stock Hu in my BRZ, does it have pre-outs? If not, what must I do? Or should I just wait a couple of pay checks and upgrade the HU before attempting an install (something I really dont want to do...inda want to keep the stock HU for a while longer until I can afford what I REALLY want as far as HU goes.)
So, advice, help? I tried Google but just ended up more confused with talk of DSPs and line levelers and stuff...I've done a basic sub and amp install in my last car with an aftermarket HU, and I do work in the electronics field, so I'm not afraid to get technical, but really the info out there is somewhat wishwashy i've noticed. Someone care to explain to me what needs be done?
LazerBrZ is offline   Reply With Quote
Old 12-04-2013, 02:52 PM   #2
FRSWiLLY
Drives: 2013 Asphalt
Nothing out of the ordinary to install and sub and and with your stock HU.
If you have done it before, you can easily do it in your brz. Two pre-outs for the sub on the back of the HU and tapping into the power wire for your amp. Best of luck and go get MOAR BASS!
FRSWiLLY is offline   Reply With Quote
Old 12-06-2013, 01:30 AM   #3
Dsmith1992
10 Series Colorado
Drives: Scion FR-S 10 Series
i dont think the brz headunits have rca pre amp outputs, but i am in the same boat as you, my thing is keeping the stock headunit
Dsmith1992 is offline   Reply With Quote
Old 12-06-2013, 09:14 AM   #4
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
You are correct, no rca pre amp outputs in the BRZ. The LC7i is a good option to add them.
http://www.ft86club.com/forums/showthread.php?t=27139
sure74 is offline   Reply With Quote
Old 12-06-2013, 10:37 AM   #5
Dsmith1992
10 Series Colorado
And the 2014 pioneers dont have em either i got 2 10" type r subs gonna go in if i can get it to work
Sent from my XT910 using Tapatalk 2
Old 12-06-2013, 12:53 PM   #6
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Nothing really needs to be done, but adding an Audio Control LC2 between the HU and the amp (speaker level into the LC2 and pre-outs from LC2 to amp) will definitely help to clean up the signal and make it alot nicer, plus basically properly balance the audio and boost the bass properly so the amp is seeing good signal levels. It's not very complex DSP, but it does do the job pretty well.
^GT5 Replay Photo Mode^
Old 12-06-2013, 01:02 PM   #7
SkullWorks
Drives: SSM LT MT BRZ
I Removed the factory amp in the trunk and took the input from the HU (which is tied directly to the front stage) and put that through a cheap line level converter (you may not need to do this my Alpine amp only accepts line level input IE RCA)
I then split the RCA side of the line out and used it for Channels 1, 2 and SUB
I ran the channels 1 and 2 back to the door speakers (the sandard output side of the factory amp)
and...Sub out put goes to my Sub...no surprise right?
There is also a Amp on signal line in the factory amp connector...so that worked great, only had to run Power and ground to the AMP, and the doors don't rattle anymore because the mids in the doors aren't trying to act like subwoofers anymore.
SkullWorks is offline   Reply With Quote
Old 12-07-2013, 09:04 PM   #8
LazerBrZ
LazerBrZ's Avatar
Just finished installing my sub today. I will confirm that there are no rca connections on the back of the stock HU. However I used a line converter( about 20 bucks at my local car audio shop) hooked straight into the harness for the oem amp which will provide your rca outs to the real amp.
Sent from my HTC One X using Tapatalk
Old 12-11-2013, 04:54 PM   #9
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
do they sell a harness for the stock brz headunit so i can plug in rca's?
NYCsubaruBRZ is offline   Reply With Quote
Old 12-11-2013, 05:00 PM   #10
SirBrass
SirBrass's Avatar
Get an Audio Control LC2. It's basically a bass restorer/balancer (b/c the stock HU will remove a lot of bass to not badly overdrive the stock crap speakers) with line driver pre-outs on the output and speaker line inputs. About half the cost of a good aftermarket HU.
Old 12-14-2013, 07:00 AM   #11
NYCsubaruBRZ
please explain a little more (how to get rca out from HU)... thanks
Old 12-21-2013, 06:35 PM   #12
Dsmith1992
10 Series Colorado
From what i have found there is now way to get actual rca out on head unit, but after researching for my frs with the newer bespoke headunit since it does not have rca output either. Rock ford fosgate makes a high level to rca converter that i plan on using and taping into the factory audio amp signals. The product is very handy and works well from all the reviews. Here is the model so you can look into it. Rockford fosgate rfi2sw and its like 10 bucks
Old 12-29-2013, 02:12 AM   #13
Nitro_FRS
Drives: sexy
Sorry dont mean to cut in on someone else's topic but since we are on the subject does the 2013 frs pioneer HU have rca output?
'13 FRS
"Layla"
Nitro_FRS is offline   Reply With Quote
The Following User Says Thank You to Nitro_FRS For This Useful Post:
hmong337 (12-29-2013)
Old 12-29-2013, 02:34 AM   #14
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
The 2013 "base" head unit does, yes. Not the 10 series or 2014 though.
oldpueblo is offline   Reply With Quote
Subwoofer now available Opie Electronics | Audio | NAV | Infotainment 97 08-15-2015 08:23 PM
4 Subwoofer fit? Iceblazer Electronics | Audio | NAV | Infotainment 19 11-27-2013 08:17 PM
Adding Subwoofer to stock HU RAN94A AUSTRALIA 49 05-20-2013 07:53 AM
Subwoofer? yomchi1989 AUSTRALIA 31 09-06-2012 09:23 PM
Does BRZ and FRS come with a Subwoofer? R0ME0 FR-S / BRZ vs.... 6 05-07-2012 02:54 PM
