Old 12-03-2013, 07:12 PM   #1
stock
stock's Avatar
Drives: 2015 FRS Steel (manual)
CS or STX
Guys,
Planning to race next year on a local level. (autox)
I have a few yrs experience, FWIW, 2000-2004/5 ish. Gave it up for various reasons.
Debating whether to race my new FR-S in Stock CS class or STX.
I know I can move from CS to STX. BUT... I am about to buy some rims. I am buying Enkei RPF1 rims and although the 17x7 look to be perfect for CS, I am thinking 17x8 and going to STX. Not much choice in tires at that size though.
I like that both classes will use 140 rated tires (if I understand correctly?)
Any thoughts?
I presently have a catback and a TRD intake. No other mods. I know the intake comes off if I race CS. I have all the original intake parts, so its no problem.
stock is offline   Reply With Quote
Old 12-03-2013, 07:56 PM   #2
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Classes are silly. Just run in the *fun* run group and compare your results with other cars / drivers. I don't want someone telling me what I can and can't put on my car, sorry. I think there should be *some* classes to separate out the run groups, but not so many different ones.
mike_ekim1024 is offline   Reply With Quote
Old 12-03-2013, 09:30 PM   #3
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
You can run a 245 tires on an 8" wheel so there's plenty of tire selection. I'm not sure if there will be rubbing, though. Do you know about the local competition for both classes? You may want to run against the class with the larger numbers/tougher competition.
G_Ride is offline   Reply With Quote
Old 12-04-2013, 04:06 AM   #4
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
I think, since the TRD intake is a dealer option that it can be used in CS. Hmm what's everyone else's thoughts on this?
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 12-04-2013, 08:08 AM   #5
TimR
TimR's Avatar
Drives: Limited Lightning Red
I agree with G Ride and suggest finding out what the competition is like in either class first. Here in Chicago region there are usually only 2 or 3 cars in CS, but in STX it is consistently a field of 10 or so cars and the competition is usually very close (unless the Milwaukee boys come down and thrash us all). I run STX with 17x8 wheels and whiteline camber bolts as my only mods, and the car is reasonably competitive - and I have lots of room to grow into future mods.
TimR is offline   Reply With Quote
Old 12-04-2013, 08:29 AM   #6
stock
stock's Avatar
Bottom line is I feel limited in the mods I might make (if I go to CStock).
STX is more in line with what I'd like to do to the car.
Wider rims/tires
overpipe etc.
Lowering.
I just like to be in a class I can be competetive in. If the car does a fair job in STX, I'd like to be there.
Old 12-04-2013, 08:44 AM   #7
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Dealer add-ons are not necessarily legal, if they fit under the comfort/convenience clause then they would be, but performance ones such as dealer option STi/TRD springs or the intake like you mention are not. They have to be part of a manufacturer specified trim package.
EDIT: I checked Scion's site and the way they market that part, it does appear to be a manufacturer optional part... not JUST a dealer installed performance compoent... this one may be a gray area that needs further clarification.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 12-04-2013, 09:38 AM   #8
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
If you just want to mod your car and have fun then just do STX. Staying within the Stock rules is a pain unless your plan is to try to start being competitive and going to National events. I am running CS because I plan to go to Nationals, but I sure would love to have some more leeway to modify things.
DylanFRS is offline   Reply With Quote
Old 12-04-2013, 09:49 AM   #9
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Originally Posted by mike_ekim1024 View Post
Classes are silly.
Thank you! SCCA's Solo2 classing is crap imo.
PoorMansRacing is offline   Reply With Quote
Old 12-04-2013, 09:52 AM   #10
PoorMansRacing
Anorexic
Honestly, I would take a novice season in CS even if you have experience. The car does extremely well in CS - if you're a good driver, you can definitely be competitive. Get use to the feel of the car, plan your mods, then consider STX. You'll improve your reflexes and car control and have a better idea what should be modified in order to prep for STX.
Old 12-04-2013, 12:30 PM   #11
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Stay in Stock for a year, learn the car and see how much you want to jump into autocrossing again. If you are just getting back into it starting to mod the car to be competitive might steer you away again. If you just want to have fun I think staying stock and enjoying driving and not working on the car/modding all the time is the way to go. Unless you are like me and can't not try to void warranty's.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 12-04-2013, 12:41 PM   #12
stock
stock's Avatar
Its the modding I like. To a certain extent...
My logic is saying ----- buy the 17x8 rims and try autoxing again, if I dont wish to continue, I still have a great set of light, wide rims that look great.
Old 12-04-2013, 03:34 PM   #13
ReThink
ReThink's Avatar
Agreed. I would like clarification...
Buy an OEM intake and be done with it...or commit to STX and start investing...
Sc10n FRS #0664
Old 12-04-2013, 03:59 PM   #14
toeout
Tune + header alone are worth going to STX. Something you get enjoy every time you drive the car.
toeout is offline   Reply With Quote
cs stx autox
