Old 11-29-2013, 10:31 AM   #1
Anthony7515
brz owner
Drives: 2013 Subaru brz white
Do they remove catalytic converter if u get a invida n1 catback?
Do they remove the catalytic converter?
Anthony7515 is offline   Reply With Quote
Old 11-29-2013, 10:37 AM   #2
MAPerformance
Drives: Asphalt FRS
No, it is a "cat-back" so it will bolt up to the OEM front pipe. The front pipe houses the secondary cat on these cars.
MAPerformance is offline   Reply With Quote
Old 11-29-2013, 10:43 AM   #3
whataboutbob
AutoX-10/10ths every run
No. The last cat in the system is on the front pipe. The N1 replaces everything after the front pipe to the tips.
Build thread:Here
Old 11-29-2013, 10:59 AM   #4
Anthony7515
brz owner
I'm also getting a front pipe resonated
Old 11-29-2013, 11:06 AM   #5
MAPerformance
Drives: Asphalt FRS
If you are getting a resonated front pipe, then you WILL be getting rid of one of your cats.
Old 11-29-2013, 01:53 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Tell me... why must you post the same thread/topic in all different sections of the forum?
http://www.ft86club.com/forums/showthread.php?t=52414
It's pretty much every other thread you start. You ask a question and then start a new one within minutes, either in the same subforum or other section.
We want to help, but you also need to learn to post once and wait for a reply...
-alex
FS: OEM downpipe / Secondary catalytic converter cb7tuner Engine, Exhaust, Bolt-Ons 2 06-07-2016 01:17 PM
Explain catless header/catalytic converter/O2/losed Loop regal Engine, Exhaust, Transmission 9 07-13-2015 11:34 PM
Just got a catback do they remove the catalytic converter Anthony7515 Engine, Exhaust, Transmission 17 12-03-2013 04:47 PM
Header with Catalytic Converter ScionFR-S Engine, Exhaust, Transmission 21 09-21-2013 12:29 PM
Catalytic Converter question! destinharper Engine, Exhaust, Transmission 4 08-27-2013 09:56 AM
