Old 11-27-2013, 03:19 AM   #1
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
18x9.5 +45?
Hey all,
I am looking to purchase some Enkei Kojins, and I love the concave look, sadly that means that I have 2 choices: 17x9 +45, or 18x9.5 +45.
The coils I am looking at are probably going to be Megan Racing EZ Street Series, not looking to break the bank here I don't track my car just street driving.
I have talked to @Fancy (he runs the 18x9.5 +45 on stock coils) and has to use a 8mm spacer in the front. My question is, does anyone have an idea if I had coils would I need to run a spacer for the 18x9.5 +45's?
Here are pics of @Fancy 's FRS pics taken by him of course, love the look ! He runs 245/40/18 Falken 612's
Hope you don't mind the shout out!
His thread is here http://www.ft86club.com/forums/showthread.php?t=9846
SoCal909 is offline   Reply With Quote
Old 11-27-2013, 06:52 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I asked same question recently and was told by a few yes it will clear coils. In regards to coils you want be noted those ride real rough. You don't want to skimp too much on coils at least do STs or something.
Old 11-27-2013, 07:23 AM   #3
mike the snake
If you run 18x9.5 in front, you will hit the springs unless you go with coilovers.
I went with ST coilovers and couldn't be happier.
I went with Raijins, 18x8.5 front and 18x9.5 rear, and the fronts are not as concave as the wider rears.
The rears are perfectly flush, but the fronts need a 5-10mm spacer to be perfectly flush. With the front spacers, you MAY be able to fit the 18/9.5/45 without hitting the coils, but you'd need to confirm that.
For the extra few bucks, the ST coilovers IMO are a much better choice over just new springs.
Old 11-27-2013, 11:18 AM   #4
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
You don't need spacer if you have coil overs, also you can go 255 with a little camber and 265 with some camber with a front fender roll.
adprokid is offline   Reply With Quote
Old 11-27-2013, 06:44 PM   #5
SoCal909
SoCal909's Avatar
Thanks for all the responses, I'll look into the ST coils
Old 11-27-2013, 07:10 PM   #6
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Don't buy the Megans. At a minimum buy the BC's.
If you can spend a little more buy FortuneAuto 500's ($1200) or ST's ($1200, with camber top plate). You'll need a front camber plate if you lower it.
Talk to the guys at FT86SpeedFactory.com, they are awesome and will find the perfect setup for you at a good price.
mwjcyber is offline   Reply With Quote
Old 11-28-2013, 01:24 AM   #7
DAMotorsports
Drives: 2013 Scion FRS "Raven"
275 will fit in the front but 265 would be great I believe DesertFrs has a set for sale at a great price. You will need a coil over to give you a few more inches of clearance
DAMotorsports is offline   Reply With Quote
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 03:15 AM
** Volk TE37SL 18x9.5 +40 (Rear) 18x9 +45 (Front)** SOURCE,LLC Wheels and Tires 23 09-17-2013 09:25 PM
Considering going from 18x8.5ft/18x9.5back to 18x9.5 squared what to expect?? OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-18-2013 10:10 AM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
