Old 11-25-2013, 10:07 AM   #1
Foobar
SLO NO MO
Foobar's Avatar
Is it recommended to change tune for winter?
Total noob question here, but with temperatures/air density/fuel mixtures changing for cold-climate locations, is it recommended to get a tune tweaked for winter conditions versus using what was optimal over the summer? Not sure if the ECU compensates for these variables on its own, or if the tune has to.
Old 11-25-2013, 12:22 PM   #2
Frostyman
Drives: 2013 Raven FRS
From what I understand, there are considerations in place for air density changes in most tunes.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 11-25-2013, 12:41 PM   #3
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
You shouldn't need to change tune for different weather. If you want a proper tune check our our OpenFlash Tablet: http://www.procedetuning.com/BRZ_FR-...ash/index.html
Even if you are in cold climate our tune has accounted for hot/cold temperatures/air density/fuel mixtures/timing changes. If you want a better understanding of how it works feel free to give us a call.
Cheers
Robert@Vishnu
Robert@Openflash is offline   Reply With Quote
Old 11-25-2013, 12:43 PM   #4
Muskokan
Drives: white Sport-tech
small threadjack question here...
do you folks with costom tunes get the popping sound on cold mornings?
http://www.ft86club.com/forums/showthread.php?t=43408
Muskokan is offline   Reply With Quote
Old 11-25-2013, 01:15 PM   #5
Foobar
SLO NO MO
Foobar's Avatar
Cheers
Robert@Vishnu
Thanks Robert - I've got a Vortech so your OFT isn't really an option for me yet. Appreciate the input though!
Old 11-25-2013, 01:45 PM   #6
DJCarbine
Thupercharged
DJCarbine's Avatar
If you are running ecutek (or any real tune for that matter) the IAT temps have fuel compensation so cold weather does not require a retune if those values are correct. You also have atmospheric pressure, manifold pressure.... lots of sensors and tables to compensate from a 90*F sealevel drive, to a thousand foot high romp through the mountains at 30*F
IMO thats just what is is though... compensation. Depending on your mods, those compensation tables may not do their job as well and could need tweaking.
Wouldnt hurt to do a datalog and see where your fuel trims are
2013 FRS
Vortech V3 11psi
Old 11-25-2013, 01:51 PM   #7
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Even our custom tunes have built in compensations for environment variables such as air temperature, density, altitude, etc. These compensations apply to the major areas of the tune like air/fuel ratios (AFR), ignition timing, cold start fuel and ignition compensations, etc.
We also include the same compensations for forced induction setups. On turbocharger applications, we use air temp, density, and altitude to adjust boost as well.
You shouldn't need a separate winter tune as long as your tune has the proper compensations in place. The stock tune on the ECU includes environment variable compensations too.
- Bob
Circuit Motorsports is offline   Reply With Quote
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
Time to change the winter tires? dem00n NY / NJ / CT / PA 8 01-11-2013 12:51 PM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 09:53 AM
Change oil before or after winter storage... or both? switchlanez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 11-07-2012 04:30 PM
