Old 11-24-2013, 10:49 AM   #1
bjun
bjun's Avatar
Drives: white premium brz M/T
Anyone having problem with HKS exhaust?
Hey guys, I have a HKS HI-Power Spec-L Exhaust for the BRZ, and I installed it myself. It's been over 6 months, but I recently noticed a problem. I lowered my car, which sits about 3 inches off the ground. But, sometimes when I go over bumps I hear a loud bang. When I looked under my car yesterday for the first time, I saw that the midpipe of the exhaust is sitting 1.5 inches off the ground. Is it normal for the pipe to be angled downwards where it sits lower than the car itself?
Point 1 is 1.5 inches off the ground and point 2 is 2 inches off the ground.
bjun is offline   Reply With Quote
Old 11-24-2013, 03:13 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I don't have any comments on the HKS exhaust but I'll just leave these photos here
Sent from my IBrick
Old 11-24-2013, 03:29 PM   #3
bjun
bjun's Avatar
So I guess it's normal to be like that
I feel like it's going to break some point in time though :/
So yours hits the ground often also?
Old 11-24-2013, 03:30 PM   #4
MikeNYC
MikeNYC's Avatar
Drives: Ultramarine Scion FRS
welcome to having a lower car you just need to take it slow over bumps. you can try smaller hangers but it might pull you exhaust tips up to the rear diffuser too much
MikeNYC is offline   Reply With Quote
Old 11-24-2013, 03:30 PM   #5
SmsAlSuwaidi
Boosted
Well it's the way the exhaust routes I guess. My exhaust leaks at every flange (front pipe) (mid pipe and the rear) but you have to remember I'm lowered over 4"s and I drive on it
I'm putting my stock exhaust back
Sent from my IBrick
Old 11-24-2013, 03:34 PM   #6
bjun
bjun's Avatar
Ya, I was just getting paranoid maybe I installed wrong or something, thanks
Old 11-24-2013, 03:35 PM   #7
MikeNYC
MikeNYC's Avatar
if i take a speed bump at more then like 10 mph ill hit my exhaust on it i think mine hangs down alittle too i dont know the measurement from the ground though and im dropped almost 2"
Old 11-24-2013, 03:37 PM   #8
bjun
bjun's Avatar
It's quite annoying. Especially because I paid a good amount of $ for the exhaust, and it's scraping everything...
Old 11-24-2013, 03:40 PM   #9
MikeNYC
MikeNYC's Avatar
yeah i feel ya i have the injen exhaust but i knew what i was getting myselft into when i lowered my car and driving in NY with a lowered car is no easy task lol
Old 11-24-2013, 05:32 PM   #10
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
How low is your car? I am going to be lowering mine in the future, and don't want to scrape my exhaust either.
IAmNotTheDriftKing is offline   Reply With Quote
Old 11-24-2013, 05:35 PM   #11
SmsAlSuwaidi
Boosted
If you're going to lower your car with intentions just to go lower slightly and not slam it you shouldn't have an issue as long as you take care going up stuff
Sent from my IBrick
Old 11-24-2013, 11:24 PM   #12
bjun
bjun's Avatar
my car is about 3 inches off the ground. Lowest the kw coils will let my car go without needing camber plates
Old 11-25-2013, 02:34 PM   #13
Firestorm_86
Drives: FRS
photos of the the pipe routing was pretty freely available. my suggestion would be to trade it in for something that takes the stock exhaust route so it sits higher up under your car. i have the legamax and clearance is a bit better than the hi-power.
the nameless also hangs kinda low.
Firestorm_86 is offline   Reply With Quote
TRD Exhaust/Intake Installed - Super loud - Problem or Normal?? Chase86 Engine, Exhaust, Transmission 21 02-04-2019 01:02 AM
VVT intake/exhaust angle problem ; Need tuners advice / help NoFear99 Engine, Exhaust, Transmission 10 05-19-2013 02:36 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
Exhaust problem help? J-Money Engine, Exhaust, Transmission 4 01-24-2013 01:46 PM
Having exhaust problem, need help please ngabdala Engine, Exhaust, Transmission 11 12-18-2012 08:27 AM
