Old 11-23-2013, 12:47 AM   #1
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Traction Control Freakout.
Had this happen to day, not sure if anyone else has had the problem.
Turned traction control/all off (3 seconds.) Pulled out on a double wide empty road making a left turn intentionally kicking the rear end out. Mid-way through I had the tracing control continuiously flashing (as if it was never turned off and you spun the wheels.) The result was that slight choke (for lack of better description) of the throttle or whatever it does which resulted in a sweet 180* spinout -_-.
Soon as I see the end come around I clutch in and catch it. TC still flashing even though I've come to a complete stop. I put it into 1st and proceed to leave as I already feel that I've made an ass out of myself. So I let out the clutch and but, no movement. Car revs like it is in neutral. I shift into 2nd then back to 1st and try again. Again, tach is revving, crickets chirping and the lost traction light is still flashing with the "TC off light" and the one below it still lit up.
So I hit the push start and then restart the car. All seems to work well after the restart, didn't mess TC with the settings after restarting and drove off.
Has anyone had something similar to this happen. Just moments before I did see my low tire pressure lights come on (Temp is dropping.) Maybe a mixed signal cause the car to flip out.
Old 11-23-2013, 01:03 AM   #2
humfrz
Hard telling ...... but I wouldn't worry about it unless it does it again....sometimes they are just "touchy"......
humfrz
Old 11-23-2013, 05:04 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Auto I presume?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-23-2013, 05:40 AM   #4
Muskokan
Drives: white Sport-tech
Originally Posted by Kodename47 View Post
Auto I presume?
Words like clutch, and 1st...
Muskokan is offline   Reply With Quote
Old 11-23-2013, 06:43 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Oops. Didn't see that. Just a bit surprised you could physically put the car in gear and get nothing unless you'd done something to the clutch/drivetrain but that wouldn't explain it going after a restart.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-23-2013, 06:55 AM   #6
Muskokan
it is odd, like the last guy said it was probably just a finicky spell with the traction control, i forgot to turn it off once while drifting in gravel and it wouldnt let me apply throttle for a good 20 seconds, then all of a suddon just worked. normally it will only cut throttle for 1-2.
Old 11-23-2013, 01:23 PM   #7
mashal
DADA
mashal's Avatar
Drives: 2013
3 seconds doesn't turn it off, you have to hold it down for 10 seconds
mashal is offline   Reply With Quote
Old 11-23-2013, 01:28 PM   #8
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Nope, it's like 3-5 seconds.
I find it incredibly unusual that you put the car in gear and it didn't move. That technically should be impossible, unless somehow, your stability control used the ABS and put the brakes on completely. Did you feel the car squat when you tried to go?
- The Ancient BRZ Sacrament
by Zaku
Old 11-23-2013, 02:09 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
I agree, but he said:
The car wouldn't rev if the car was in gear and brakes fully applied unless the clutch was slipping, in which case you'd smell burning clutch.
My only other ideas are clutch had overheated and not grabbing, or simply that the gears were not put fully home and as such not actually in gear. There are no other physical options I can see.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Guff (11-23-2013)
Old 11-23-2013, 02:27 PM   #10
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Ralph Spoilsport is offline   Reply With Quote
Old 11-23-2013, 04:23 PM   #11
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
The car was just giving everyone a chance to see you!
Rampage is offline   Reply With Quote
Old 11-23-2013, 05:59 PM   #12
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I noticed when the traction is off (3 sec. trac button) it will still kick in when the car starts to jumps up and down, like if you try to drift the rear on a bumpy road, if it's a flat road, it rarely shows up. I drove all winter in the snow with the traction control off and it never kicks in as it's always smooth drifts.
Basicly when the car sees vertical G's it seems to step in anyway.
Rayme is offline   Reply With Quote
Old 11-23-2013, 06:09 PM   #13
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
If traction gets really light on one wheel it seems to do this. I've heard some people claim it is an e-dif function. There is a sharp uphill turn leaving my street so I end up doing this daily it seems.
At any rate if you pedal dance it truly turns everything off, but that requires the car to already be warm, and it is a pain in the ass to do in traffic. Wish the process was easier.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
The Following User Says Thank You to MmmHamSandwich For This Useful Post:
Guff (11-23-2013)
Old 11-23-2013, 06:16 PM   #14
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I'm sure anyone who needs to have everything off would be much better off making a cut-off switch to one or more of the abs brake sensors/any other critical sensor to the VSC, it would defenitly turn everything off. However I don't know if the computer would go back to normal upon restart.
The be all end all Traction Control topic empower-auto Issues | Warranty | Recalls / TSB 14 09-19-2017 03:41 PM
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
traction control question Sileighty_guru BRZ First-Gen (2012+) — General Topics 9 09-26-2012 09:54 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
