Old 11-22-2013, 09:24 PM   #1
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
Best Top Hat for Bilsteins?
What do you recommend for an adjustable top hat for the b14 kit?
I was going to try the white-line but after reading through the problem threads on here, I staying far away!
I believe it has to be compatible with OEM Struts not like most coilovers.
Pacific Auto is offline   Reply With Quote
Old 11-22-2013, 09:46 PM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
HVT are good non raising, Turn In concepts and RCE sel those. Racesengs new ones look awesome to say least. Vorshlagg are well known as well and have an extra degree of castor. Another non raising and good choice would be Ground Control ones, anyhow those all good choices any will be good.
Old 11-22-2013, 11:08 PM   #3
Ro_Ja
Drives: TOYOTA
Because the Bilsteins use a non-typical coilover spring (OEM diameter), you're pretty limited on options. I believe only HVT and Ground Control will work. I'm using the HVT on my B14s, but I'm sure Ground Control's are just as good, so it's all preference.
Ro_Ja is offline   Reply With Quote
Bilsteins, quick help? Pacific Auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-20-2014 01:11 PM
My Alignment with Bilsteins Pacific Auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-03-2013 12:44 AM
