Old 11-22-2013, 01:39 PM   #1
levifig
GBS Mafia Member
levifig's Avatar
Drives: N/A
Stock rims + Winter tires
So,
I've been researching this quite a bit and, while there's plenty of info on each tire model, there doesn't seem to be a lot on tire sizing for the stock rims… I guess people just assume everyone else knows their tire/rim sizing… :P
So my direct question is: will 205/55R17 fit on the stock rims (215/45R17 stock tires)? How will the speedometer be affected?
Feel free to link to good explanations on tire sizing. I'd love to see some tips collected here on winter tire sizing (e.g. narrower tires > wider tires, etc)
So… anyone?
Thank you.
--L
levifig is offline   Reply With Quote
Old 11-22-2013, 01:39 PM   #2
levifig
GBS Mafia Member
levifig's Avatar
Drives: N/A
FWIW, I've seen plenty of recommendations for 205/50R17 on the stock rims… Just not sure how the taller tire will affect the car or if it simply won't fit!
Old 11-22-2013, 03:06 PM   #3
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by levifig View Post
So,
So… anyone?
Thank you.
--L
Yes, no problem. The stock wheel is 7x17 and a 205/50 x17 will fit just fine.
The tire isn't any taller because the tread width is narrower: 50% of 205 = 45% of 215 so sidewall height is identical. (Only 2% taller, depending on actual manufactured sizes).
Don't do it though because the 215/45x17 is already narrow enough.
I actually fit 225/45x17 winters and will fit the same size summers.
Bonus, fitting either of these alternative sizes will make your speedo more accurate!
One thing to remember : fitting taller but narrower tires of the same rolling circumference makes the ride harder because ride comfort is proportional to the air spring effect of the tire. Wider tires have more volume which lowers the effective spring rate of the tire.
You also have to increase tire pressure for taller but narrower tires to compensate for this smaller internal air volume.
Suberman is offline   Reply With Quote
Old 11-22-2013, 03:24 PM   #4
levifig
GBS Mafia Member
levifig's Avatar
Drives: N/A
I was actually wondering about 205/55s… Thanks for the rest of the explanation. I think the biggest thing you said was how 215 is already narrow "enough"… I'm guessing the "enough" there has something to do with some sort of contact surface x car weight ratio.
Unfortunately, Michelin doesn't seem to make Pilot Alpin PA3 in that size…
Old 11-22-2013, 03:53 PM   #5
SamS
Drives: '13 BRZ, '99 Forester,'06 Duc S2R1k
This Miata site has a calculator to quickly compare sizes, but actual tire size will still vary by manufacturer.
http://www.miata.net/garage/tirecalc.html
SamS is offline   Reply With Quote
Old 11-22-2013, 04:09 PM   #6
levifig
GBS Mafia Member
levifig's Avatar
Drives: N/A
Awesome link! Thanks!
Now to find out if the stock rims can handle 205/55R17 (vs 215/45R17 stock tires)… I'd do 205/50 but TireRack doesn't have the Pirelli Sottozero in that size… Will I find them elsewhere?! Or even better, some Michelin Alpin, maybe the Primacy PA3s?
Cheers
Old 11-23-2013, 11:03 AM   #7
Suberman
Narrow tread is thought to drive through deep snow more easily because the leading edge of the contact patch is narrow.
That may be true but most winter driving is not done in deep snow. Most times we are actually looking for ice traction in winter, ice or hardpack. For that narrow tires offer no advantage.
Fitment of Winter Tires on Stock Rims: X-Ice 3 215/55/17 hyper4mance Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 10-22-2017 11:17 PM
FS: Gislaved NordFrost 5 (205/55/R16) winter tires on steel rims Burrcold Canada Classifieds 2 02-08-2013 06:59 PM
Poll: Winter Tires and Rims FRiSson New England 47 12-08-2012 03:15 PM
FS (Toronto) 17" Forged Rims, StarSpecs, Winter Tires, Rota bdon22 Wheels and Tires 17 10-29-2012 08:33 PM
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 08:33 AM
