Old 11-21-2013, 04:36 PM   #1
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Shiftek short shifter installation question
I am currently installing a short shifter and have come across a problem... I have the problem when installing the new shifter back in.
This is not my picture but the issue I came across. Well I managed to get it on using alot of force. Now my problem is I can't get it farther on to put the cotter pin back on(literally a hairs length) and I can't take the shifter back out.
Can I just forget about the cotter pin and be fine?
The force needed to have it come off would most likely be the same to break the cotter pin with the stock shifter.
SubaSteve is offline   Reply With Quote
Old 11-22-2013, 12:00 AM   #2
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I had to drill the inside of the bushing with a 3/8 bit to get it on properly. You don't want the shifter to come off the linkage while driving.
Shiftek claimed to have fixed the problem, but i guess not.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 11-22-2013, 02:13 AM   #3
imom
Drives: BRZ sold
I didn't get an accurate measurement because of the rubber washer, but I got close to the 10mm opening that Shiftek mentioned... Perhaps they need a little bit bigger than 10mm?
imom is offline   Reply With Quote
Old 11-22-2013, 10:19 AM   #4
Hawaiian
That guy
Hawaiian's Avatar
No, 10mm is larger than 3/8. Maybe he got an old one?
Ultramarine mt FR-S
P&L stage 1 turbo
STI Short Shifter Kit Hanakuso Engine, Exhaust, Transmission 37 01-18-2016 08:19 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Short Shifter paulieblaze Engine, Exhaust, Transmission 33 01-20-2014 11:55 AM
BPS Short Shifter Alabang 86 Transmission and Driveline 8 09-02-2013 12:58 AM
Short-shifter feel empower-auto Cosmetic Modification (Interior/Exterior/Lighting) 16 11-16-2012 11:13 AM
