Old 11-19-2013, 07:47 PM   #1
jm1681
Drives: MKVI VW GTI
Removing rear seatback (Tried searching)
I really DID try searching, but I found nothing on how exactly to get the seatback out.
I have it laying flat on the cushions right now, and I can see a bolt on both sides of the pivot, but that's it, and I didn't want to go at that bolt without knowing what I'm getting myself into.
Also, the fabric on the back seems attached to the foam pads in the trunk. Does that pop in/out or does it need to be cut?
Any help is greatly appreciated.
jm1681 is offline   Reply With Quote
Old 11-19-2013, 09:05 PM   #2
JerryMichaels7
Drives: Whiteout FRS
take those 2 bolts out and your done....
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 11-20-2013, 08:02 AM   #3
jm1681
Drives: MKVI VW GTI
Awesome, thank you for verifying
Oh, the Styrofoam pads the seatbacks are attached to, do they pop off, or do I need to cut them off?
Removing rear brake rotors? Kuzuri Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-18-2015 10:08 PM
question: how to remove rear seatback? mid_life_crisis DIY (Do-It-Yourself) Guides 15 12-11-2013 03:49 PM
Removing rear 'toyota' logo. Wise AUSTRALIA 15 08-28-2013 02:57 AM
Removing Toyota badge from rear white_knight Cosmetic Modification (Interior/Exterior/Lighting) 3 08-25-2013 10:24 AM
Help Removing Rear Seats and Rear Part of Center Console ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 08-27-2012 04:11 PM
