Old 11-07-2013, 11:58 AM   #1
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
>>FREE INSTALL or FREE SHIPPING on Select Coilovers at Prime Motoring <<
Hey All,
Wanted to extend this offer to everyone looking into coilover systems for your car. FREE INSTALL for locals or FREE SHIPPING to the lower 48 included in the already LOW pricing on the following coilover systems purchased through us. We will be running this special through the holiday season!
We carry multiple brands so if you do not see the certain coilovers you are interested in, PM us about which type of coilover suspension you are interested in and we'll get you a competitive price including install on these as well.
KW
Variant 3 - $2299.99
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
Clubsport Kit 2/Way with Top Mounts - $3759.99
These set ups were specifically designed for the Nordschleife using track day tires. By using the optional adjustable top mounts, suspension geometry can be adjusted to the requirements of the tires and the intended use.
These adjustable top mounts coupled with the independently adjustable rebound and compression dampening technology individual set up adjustments according to vehicle load, tire characteristics and different track conditions. Clubsports meets all needs for the road and the race track guaranteeing excellent handling, best performance, great agility and fantastic lap times.
ST - $849.99
The ultimate in performance, style and handling, ST height adjustable coilover kits are precision engineered and road tested to the highest standards of the German TÜV. Their threaded shock bodies allow you to customize vehicle ride height to the maximum, without compromising safety, functionality or superior driving performance.
H&R
Street Performance - $1450.00
Tein:
Street Flex - $1501.00
The Street Flex damper is the evolution of their popular Type Flex coilover. Developed to provide the ultimate balance of comfort and performance for both street driving and circuit use, along with wide-range damping force adjustment using their new Advance Needle technology and new damper valving specs, giving the driver a much more noticeable feel in damping force change and controllability. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Full-length adjustability offers separate spring preload and ride height adjustment. Updated internal components and external coatings increase durability and product life. Includes Pillowball Upper Mounts (camber adjustable for strut type applications) and is compatible with the EDFC and EDFC Active systems.
Cusco
Street Spec A Pillowball Upper Mounts - $2376.00
The Cusco Street Zero A coilover system is great for the everyday automotive enthusiast looking for a suspension kit that offers great street manners at an affordable price. This system features a unique 40-way dampening adjustment for a wide range of adjustability, and low noise rubber seats combined with individually designed bump stops provide a comfortable ride for any daily driver.
Apexi
N1 EXV - $1200.00
The N1 ExV Damper is the newest addition to Apexi's high performance street line of coilover suspension. The Expert Type V (ExV) is a full coilover suspension featuring a threaded base for precise ride height adjustment without compromising shock or spring travel. Apexi has taken their street suspension to the next level by including high performance upper mounts and 32 way ride quality adjustment for street cars that are used at the track as well. The spring rates and internal valving of the ExV has been completely refined for excellent ride quality and sports driving. The ExV was designed to cater exclusively to US market vehicles. With this in mind, internal components have been specifically engineered to withstand harsher road conditions and increased wear caused by everyday street driving. The Expert Type V was developed based upon user requests for a high performance damper that doesn't carry a typical racing suspension price tag.
Pedders
eXtreme XA Coilovers - $1440
Pedders Sports Ryder shock absorbers and struts combine the most advanced technology with Pedders’ renowned expertise in the fine tuning of damping rates for superior handling. At the forefront of sports suspension is Pedders eXtreme XA, height adjustable coil-over built to Pedders stringent quality standards. Pedders eXtreme XA features sports calibrated tunable damping, motorsport coil springs individually tuned to suit each application and a host of other high performance features including engineered mounting bracketry. The eXtreme XA is the pinnacle of performance suspension technology and the flagship of Pedders’ Sports Ryder range of specialist performance suspension products. Pedders eXtreme XA is the result of Pedders Suspensions commitment to being a leader in the steering and suspension industry with outstanding product success in both the motorsport arena and sports performance markets. The Pedders Sports Ryder eXtreme XA adjustable coil over features a 30 position adjustable bump and rebound damping setting at the CLICK of a button which enables you to fine TUNE your suspension for whenever you want to PLAY.
PrimeMotoring is offline   Reply With Quote
Old 11-07-2013, 12:04 PM   #2
PrimeMotoring
Here is another option for you guys
ISC Suspension has just announced the release of their N1 coilover suspension systems for the Scion FR-S/Subaru BRZ. Pricing is $955 Installed or FREE SHIPPING anywhere in the lower 48.
ISC N1 Features
2000R Certified, ARTC Certified 5 Year Limited Warranty: All service, rebuilds and warranty support are done here at ISC's USA facility. All custom coilover orders are hand assembled in ISC's New Hampshire location. ISC's goal is to have the best customer service in the industry.
32 Step Damper Adjustable:
Rebound/ Compression adjusted in unison via 32 step adjustment.
Pillowball Upper mounts:
For optimal performance Pillowball Upper mounts are a great feature. ISC Coilovers include pillowball upper mounts on all N1's.
Thrust Bearing Kit:
Thrust Bearing upgrades are included on all N1 ISC coilovers. This helps eliminate the chance of spring bind; a common side effect of running aftermarket coilovers.
Front Camber Plates:
FR-S/BRZ ISC N1's come with front adjustable camber plates standard.
Piston Rod Design:
High rigidity steel piston rods meet with race/sport standards. Shafts are valved according to the spring rate you choose. A Shock Dyno is used to ensure quality and consistent results.
Single Cylinder Design:
Larger cylinder and piston design to advance driving stability and dexterity. Mono-Tube damper with high pressure nitrogen.
Sports Spring:
Made from high quality SAE9254 steel Dyno tested over 500,000 times on compression inspection with less than 5% deformation.
Lowest Prices + Free Install or SHIPPING on ALL Catbacks/Front Pipes @ Prime Motoring PrimeMotoring Engine, Exhaust, Bolt-Ons 5 10-31-2013 06:24 PM
BC Racing Coilovers - Free Rear Extenders + Free Shipping + Best Prices Period No Limit Motorsport Brakes, Suspension, Chassis 36 02-27-2013 05:39 PM
