Old 11-03-2013, 07:30 PM   #1
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
RCE Tarmac Springs
When installing the RCE TARMAC springs on Koni struts with HVT hats and adjustable lower control arms, has anyone seen a rise in height on the rear end? Like to 28"?
Also, how did you tell the difference between the front and rear springs? Is it possible to install them reversed (Rears on Front, and Fronts on Rear)?
Trefoil is offline   Reply With Quote
Old 11-04-2013, 02:45 AM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Make sure the rear Konis spring perch hat thing is facing down. I installed my upside down the first time which made my rear end higher. Made my car look odd and sort of like a drag racing car. Rear springs have less number of coils in the spring if I remember correctly. Plus they should have a label on it with an R for rear and F for front.
stockysnail is offline   Reply With Quote
Old 11-04-2013, 08:42 AM   #3
Trefoil
Trefoil's Avatar
Now that you say that, and I look at the pictures (I'm at the office without the vehicle) the rear hats are facing up. That would explain why the rear install was so difficult compared to the front.
Wondered why the hats facing up didn't seem right when the mechanic put them on.
Mods, you can lock this thread. I'll make a writeup for a sticky or something to help anyone doing this suspension change with pictures.
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
Racecomp Engineering Tarmac Springs forwallblakmail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 03-25-2017 11:40 AM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 03:43 PM
RCE Tarmac 0, KW V1, and ST coilovers nakamur21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-05-2013 11:36 AM
FS: RCE Tarmac 0 coilovers r4m3n Brakes, Suspension, Chassis 2 08-13-2013 08:35 PM
