Old 10-30-2013, 05:46 PM   #1
brz Islander
Break in -interstate
Hello, new here essentially. I will be receiving my car soon and have to drive 400 miles from Florida to South Carolina. I know it's not ideal but I have to, Is there any risk toward the engine for driving 400 miles straight?
brz Islander is offline   Reply With Quote
Old 10-30-2013, 05:49 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
Keep varying your engine speed, you'll be fine.
Sent from my Nexus 4 using Tapatalk
Old 10-31-2013, 02:52 AM   #3
jkfranklin
jkfranklin's Avatar
Drives: Black Limited BRZ
i just did a 1000 mile journey and i kept it under 4 except every 100 miles i took it up to 7000 and then resumed normal driving.
Not giving advice just telling you what i did.
jkfranklin is offline   Reply With Quote
Old 10-31-2013, 02:30 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I drove it "normal" and even kept it at set cruise control speeds for hours at a time, from 25 miles to 900 miles CO > CA.
Nothing bad came out of it.
-alex
Old 10-31-2013, 02:38 PM   #5
HeubergerMotors
HeubergerMotors's Avatar
Drives: 2006 WRX TR
Location: 1080 Motor City Drive , Colorado Springs 80905
You should be fine as long as you vary like everyone else said. Also, from one of my tuners, let it go from 4,000 and cost down to around 1,000 down shift and repeat.
Also my breakin is 90% of the time soft (4,000 and under) every one hundred miles hit 7,000 peak hp 1 so every 100 miles...
Oil changed first 1,000
CE
HeubergerMotors is offline   Reply With Quote
Old 11-01-2013, 08:23 AM   #6
Suberman
Drives: Subaru BRZ Sport Tech Satin White
-alex
You can't know that yet. Incorrect break in only shows up as the engine gets old, long after the warranty expires.
If you drove your engine very hard right after break in then no ill effects are likely.
The single most important part of engine break in is to thrash the bejeezus out of it right after the initial ring seating is completed.
Thrash it too early and you'll be sorry, or more likely the next owner will be.
Anyone who thinks engines in mass produced cars are broken in by the factory needs to change his smoking materials. Rolls Royce or Ferrari yes, Subaru or Toyota? You must be delusional.
Suberman is offline   Reply With Quote
Old 11-01-2013, 08:29 AM   #7
Suberman
CE
This is good advice. Break in is to seat the rings. Pulling intake vacuum after accelerating helps this process. Doing this cools the rings immediately after acceleration heats them up, which is what you need the engine to do.
You need to load and unload the rings periodically. You need to avoid overloading the rings (high combustion pressure develops very high ring loads ). You need to avoid overheating the rings (high combustion pressures or high rpm or both tend to overhear the rings). You need to extend the rpm range after initial break in to prevent the development of no wear ridges too low in the bores. A bad case of lazy break in can lead to broken top compression rings if a no wear ridge develops too low in the bore.
Changing the oil at 1,000 miles is no longer necessary and might delay full break in. Believe it or not but any extra metal powder that passes the oil filter might help the seating of the rings. It certainly doesn't hurt. However, changing the oil early is unlikely to adversely affect an otherwise correct break in.
Break In Again? Awstryker Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-07-2013 11:53 AM
Break in's over! Jertronic Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-06-2013 10:39 AM
Break in Y/N ? FiRStscion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 83 07-26-2013 12:41 PM
Break-in period...what's really going on? CaptainSlow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 04-27-2013 01:43 AM
Break in ipothas Issues | Warranty | Recalls / TSB 11 10-21-2012 04:41 PM
