Old 10-28-2013, 01:50 AM   #1
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
A local Toyota dealership jacked my car up.
I took my car into RK toyota in Hampton to get some issues looked at. The list is below.
Rough idle
car has died twice in neutral
crickets
window is making a popping sound
car backfires
Car wont shift into 2nd well up or down.
The performance mods to my FRS; J2 exhaust, Injen intake and innovate wideband welded into the stock header.
I know the rough idle was caused by the Injen intake and the car shutting off at a stop in neutral was related so I removed the intake. I put the stock intake on and after resetting the ECU and letting it relearn I still had a rough idle.
SO I took the car in, They had the car for about 10 hrs.
They said my VIN did not fall under the reflash group. that there were no codes on the ECU. They then said that the rough idle was caused by a a damaged 02 snsor that had hit something.
I went out to my car and opened the hood. Both my upstream and downstream o2 sensors looked brand new. No impact marks.
SO I started the car up and immediately I noticed my car was much louder than normal. Assuming it was a could start I drove it home but the car did not get quieter. So then I lifted the car up and what do you know. Who ever drove my car bottomed it out in a pot hole or in the shop and smacked the crap out of my wideband 02 sensor. Now the car idles like complete crap. I plan to remove the wideband and weld the header late this week and see if it helps.
It makes me mad that whoever drove it;
a. thought that the wideband was stock
b. damaged my car and blamed it on me
I have had the crickets replaced (High pressure fuel pump) once and they wont replace it again.
I did not buy my car with this issue and it makes the car sound like crap.
I wish they will find a real solution.
Also they disabled all of my TPMS sensors at the dealership. WTF that makes me mad.
I only know this because I swapped my wheels again with another set I have in the garage. The paper they gave me said there was a tpms code stored. So apparently they just disabled it. great.
Toyota does not know how to work on this car.
I have so mch I want to do to this car but I am always worried about the issues toyota cant fix. They couldn't find solutions to any of theother issues i mentioned.
Maverick22 is offline   Reply With Quote
Old 10-28-2013, 03:27 AM   #2
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
The fuel pump I can understand them not wanting to replace again, because it's only a temporary fix to remove the crickets. I thought I got lucky with my car but literally right after my break-in period ended and I pulled into my driveway after my first spirited drive the crickets attacked. I was pretty upset but there's nothing that can be done right now.
I'm not going to bring up the fuel pump issue to my local Subaru dealer until there's a confirmed 100% permanent fix for the pump (preferably a part # for the pump as well) because I don't want to waste anyone's time.
The rest of it though, that sucks man.
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 10-28-2013, 05:27 PM   #3
JSMIL
JSMIL's Avatar
Drives: FRS 10 series
Rough idle
crickets
car backfires
They told me the same thing about not replacing the fuel pump. Call up Scion and make a complaint telling them there is a new fuel pump and part number to acompany the TSB revision dated 17 March. I got a call today saying they would change it.
JSMIL is offline   Reply With Quote
Old 10-28-2013, 06:40 PM   #4
Allch Chcar
Drives: N/A
It sounds like the wideband Lambda sensor was damaged before you took it in. Since it was already causing the rough idle with and without the aftermarket intake. Then when they reset the ECU it went to stock maps, making it run even worse.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 10-28-2013, 06:54 PM   #5
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
That has been the worst toyota/scion dealership I have ever been too. Sucks you had to experience them
Sent from my SCH-I605 using Tapatalk
UltraMarine86 is offline   Reply With Quote
Old 10-28-2013, 11:30 PM   #6
cdemaar
Drives: 2013 Scion FRS
Rough idle
crickets
car backfires
My customer Josh just took his 10series FRS over to priority in greenbriar, and wrecked his car. They hit something in the front and then pulled it around hoping he wouldn't notice. I take my car to First Team Toyota/Scion on western branch blvd in Chesapeake. They are always really informative and polite. They do great work and won't wreck your car! Haha
cdemaar is offline   Reply With Quote
Old 10-28-2013, 11:32 PM   #7
cdemaar
^ truth
Old 10-29-2013, 04:04 AM   #8
Maverick22
Maverick22's Avatar
The wideband was unhooked and I was running a stock tune. The goal was to monitor the stock AFR.
Old 10-29-2013, 07:34 AM   #9
infinite012
Drives: 13 DGM BRZ Ltd
Take your car to Charles Barker Toyota. There's a member on this forum who used to have a red FR-S with Gram Light 57xtremes that works in the sales department, but I'm sure he could give you a few pointers on who to take your car to for service.
infinite012 is offline   Reply With Quote
Old 10-31-2013, 08:26 PM   #10
Frostyman
Drives: 2013 Raven FRS
You are referring to Josh. Still a great guy, and still the place to go if you need help, despite selling. lol.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
The Following User Says Thank You to Frostyman For This Useful Post:
infinite012 (10-31-2013)
Old 11-30-2013, 01:15 AM   #11
n0m0h0s
n0m0h0s's Avatar
Drives: #2148 frs 10 series
Send a message via AIM to n0m0h0s
What do you mean disabled tpms? Never heard of it.
n0m0h0s is offline   Reply With Quote
Old 11-30-2013, 02:24 AM   #12
Bad Habits
Bad Habits's Avatar
Drives: br zed
Uh how the hell did they expect a customer NOT to see damage to his/her own car???
Bad Habits is offline   Reply With Quote
Old 11-30-2013, 01:00 PM   #13
raptor87
Drives: 2013 DGM BRZ Ltd
I didnt see an option to disable TPMS in techstream it would be nice to know how since my winter wheels dont have TPMS
raptor87 is offline   Reply With Quote
Old 12-01-2013, 01:37 PM   #14
connorlug
Drives: #1553 10 Series FRS
Rough idle
crickets
car backfires
1. It's impossible to disable the TPMS system. They didn't disable the system they deleted the code.
2. You had a rough idle before you went in. Your car was most likely damaged underneath before you brought it in, if it had the same rough idle before and after.
3. If you're going to put aftermarket parts on your car, don't expect the dealership to spend time trying to fix it for free.
Sincerely, A frustrated toyota tech
connorlug is offline   Reply With Quote
The Following 3 Users Say Thank You to connorlug For This Useful Post:
asia_minor (12-02-2013), pche (12-01-2013), strat61caster (12-04-2013)
Local Toyota dealership paints FR-S mural draggin_az FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 04-20-2013 07:21 PM
Toyota 86 at a dealership in Montego Bay Jamaica RyPaul FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 01-05-2013 02:52 PM
Local Dealership Service Issues 31katys Northwest 9 12-29-2012 08:01 PM
Toyota Dealership Stock JiB AUSTRALIA 55 08-15-2012 06:03 AM
My local US Toyota dealership now taking deposits! dookie11 Scion FR-S / Toyota 86 GT86 General Forum 20 09-12-2011 10:51 AM
