Old 10-27-2013, 06:12 PM   #1
86GT
Drives: MK7 Golf R
Noise from motor
I recently gave my BRZ (~1400 miles) to the dealership to get the fuel pump replaced (recall due to "chirp" noise). After I got back the car, I am noticing a weird noise from the motor that I am not sure was present before. Anyone else thinks the sound is not normal? Should I get it checked?
Attaching the sound clip (notice around the 6 second mark)
86GT is offline   Reply With Quote
Old 10-27-2013, 06:25 PM   #2
Tsungfai
Tsungfai's Avatar
Drives: 2013 Scion FR-S Raven
My car makes the same exact noise at idle, I believe it's just the direct injectors working.
Tsungfai is offline   Reply With Quote
Old 10-27-2013, 06:27 PM   #3
FR-S Matt
How many more hundred posts of this noise are we going to read that's normal with this engine? lol
Old 10-27-2013, 06:57 PM   #4
86GT
Drives: MK7 Golf R
Thanks for confirming. Though it sounds odd to me.
Maybe I should have searched for a thread with a audio clip.
Old 10-27-2013, 08:43 PM   #5
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Definitely normal. This car has a lot of tech thrown into it despite the fact that it's supposed to deliver a pure driving experience. What you're hearing as others have said is the direct injection system when idling. Despite the noise, the DI system provides a smoother idle than relying on the port injectors alone.
There's nothing wrong with your question though. You heard something that you hadn't heard before so you posted it. Most likely, you were never listening for it before so that's why you never heard it. It's good you know what the sound is now. That's what these forums are for.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 10-27-2013, 11:25 PM   #6
TopGearSolutions
TopGearSolutions's Avatar
Drives: C6 Corvette Z06
Sounds normal.
TopGearSolutions is offline   Reply With Quote
Old 10-27-2013, 11:38 PM   #7
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
If you ever hear this engine quite or sounding normal, then you should seriously look into it.
Old 10-28-2013, 08:29 PM   #8
86GT
Drives: MK7 Golf R
Thanks for the assuring responses guys.
So, the DI system isnt always on? Cause when I started the car, it wasn't running and then it turned on after some time.
Old 10-28-2013, 08:44 PM   #9
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
When you first start the car (cold start) it's not running solely off the DI system. That's why when you first start it, you see that it idles higher. Once the DI takes over, you notice the RPM drop down and you will hear the DI system (i.e. your initial post) usual ticking. That's the best way I can explain it.
Old 10-28-2013, 10:12 PM   #10
86GT
Drives: MK7 Golf R
Actually when I was capturing the audio, the motor was warmed up. I had been for a spirited drive and got back. After I noticed the noise in my garage, I turned off the car and turned it back on after 2 mins. The noise wasn't present when the car started but came on after ~15 seconds.
BTW, I am not worried now that I hear that the noise is expected. I am just trying to understand the reason behind without getting too deep into it.
Old 10-28-2013, 10:19 PM   #11
utekineir
blowhard
Drives: frs, project forester
Same exact thing on every forum with di cars.
utekineir is offline   Reply With Quote
Old 10-28-2013, 10:25 PM   #12
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Exactly, you turned the car off and started it again. The process starts over.
Who has a built motor? Fabron757 Forced Induction 77 11-19-2020 10:04 PM
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 10:21 PM
anyone want a new FA20 motor?? bacon_cheese_beer Scion FR-S / Toyota 86 GT86 General Forum 22 10-07-2013 10:43 AM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
