Old 10-24-2013, 03:00 PM   #1
muffinz
Drives: 2013 DGM BRZ Ltd
WARNING: Inevitable Rust Location!
Hey Everyone,
I have discovered a potential problem with the design of our car that leads me to believe the driver side rocker panel between the wheel and the front door will rust prematurely.
Background:
I was installing my Rallyarmor mudflaps and when I pulled the fender liner to install clips, I found that I had rotting leaves and disgusting shit all inside the rocker panel in the area in the red rectangle. I pulled this all out and it smelled disgusting.
The Problem:
Rainwater is drained down the driver side windshield wiper pivot area of the car and channeled through the rocker panel eventually spilling to the ground. There is no screen or anything to prevent leaves and miscellaneous debris from getting pulled down their and accumulating.
The (annoying) Solution:
Periodically pull back your driver side fender liner and clear out the rocker panel. After I cleared mine out, when I washed my car, water was gushing out of there.
I will try to take better pics showing the drain locations and the area that was full of debris.
Note: if you live in an area with no deciduous trees, then lucky you.
Cheers
Last edited by muffinz; 10-24-2013 at 03:02 PM. Reason: Car in the pic is not mine
muffinz is offline   Reply With Quote
Old 10-27-2013, 09:14 PM   #2
FnFast
Doctor
FnFast's Avatar
Drives: Fast
Can you paint with a rust free coating?
Jeremy Clarkson "If you go though the Pearly Gates, backwards, in a fireball, that's a cool way to die!"
2013 White Pearl BRZ Limited 6MT - 15% Tint, Debadged, HIDPowerhouse LED Interiors and Dome
FnFast is offline   Reply With Quote
Old 10-27-2013, 09:58 PM   #3
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Thanks for the heads up, I was trying not to park under trees to keep that crap out.
If that much is collecting there already it would definitely cause a problem later on.
SpeedyJay is offline   Reply With Quote
Old 10-27-2013, 10:37 PM   #4
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Good thing ill have rust proofing done soon
Young_makaveli is offline   Reply With Quote
Old 10-28-2013, 12:31 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Don't you see, this is part of Toyota's initiative to "Go Green" - they're including a free composting system with every Twin!
Alternatively: That's where the crickets live!
Originally Posted by humfrz
I'm old and lazy
Old 10-28-2013, 03:15 PM   #6
infinite012
Drives: 13 DGM BRZ Ltd
I've noticed leaves in there as well as behind my fender trim.
infinite012 is offline   Reply With Quote
Old 10-28-2013, 04:21 PM   #7
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Any rust proofing/or paint won't last long. The leaves and dirt act as a sponge holding water on the metal. Eventually it if going to find its way to bare metal. The bolts and C-clips that hold the fender on (where they rub) will be a good starting point.
Old 10-28-2013, 04:24 PM   #8
OrbitalEllipses
Drives: Attitude
Problem for the next owner, lol.
Old 10-30-2013, 07:10 PM   #9
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
Holy FUCK, you were not kidding on this. This is only what I could reach with my finger. There is so much more in there that I need to vacuum out of something. Maybe get in there with a screwdriver. Does anyone recall what our warranty is for perforation due to rust?
Evil Jesus is offline   Reply With Quote
Old 10-30-2013, 07:19 PM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
o lawd jesus
Old 10-30-2013, 08:19 PM   #11
Evil Jesus
Evil Jesus's Avatar
o lawd jesus
Thank you for your concern!
Old 10-31-2013, 06:07 PM   #12
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
Sry bro, car is done.
jks aside, Canadian FRS come with mud flaps that make pulling the liner a b!tch. Is there no other solution? other then the warranty i read somewhere that covers body rust up to 5yrs?
umpadupa is offline   Reply With Quote
Old 11-02-2013, 01:48 PM   #13
daftpunk
daftpunk's Avatar
Drives: 2013 Scion FRS
Thank you so much for reporting this!
Im going out to check on that spot asap and will probably start spraying the inside with WD40 regularly. Hating the fact that the debris could've been holding water in that spot the 10 months I've had the car...
The worst thing about buying a brand new car is that you'll never know if they end up being vulnerable rust buckets like the mazda 3's =(
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 11-02-2013, 04:28 PM   #14
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Good catch, I'll clean 'er up and spray lot's of rust check in there, as everyone should do before winter
Rayme is offline   Reply With Quote
Greddy evo 3 rust... MontrealFRS Engine, Exhaust, Transmission 9 05-05-2013 07:57 PM
It's inevitable. KSC Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 04-28-2013 07:22 PM
Lug Nut Rust Wesley Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 04-14-2013 07:06 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
Rust already? Fugazi BRZ First-Gen (2012+) — General Topics 9 08-26-2012 02:36 PM
