Old 10-23-2013, 01:19 PM   #1
Flyfish1624
Drives: Scion FRS
Suspension
I've had my FRS about a month and new to the club here. Long story, but I have to replace my shocks. Any suggestions on what to put on?? Looking for something middle of the road and hopefully keep it under $1,000.
Flyfish1624 is offline   Reply With Quote
Old 10-23-2013, 01:29 PM   #2
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
I'd look at Koni's shocks/struts. The front shocks are inserts so hopefully you still have your old ones.
Books is offline   Reply With Quote
Old 10-23-2013, 01:38 PM   #3
Racecomp Engineering
Your only options right now are stock and Koni (which use an insert for the front and can be a little difficult to install).
Bilstein will have an option very soon.
Are you pairing with stock springs?
- Andy
Old 10-23-2013, 01:47 PM   #4
Flyfish1624
Drives: Scion FRS
I bought this car used from a subaru dealership, it was lowered 2" and has after market coil overs (green). Got the oil changed first thing and the guy that changed my oil said 3 shocks were leaking, then I did notice suspension has progressively gotten worse. Unfortunately not knowing a lot about cars i found this forum and thought I would reach out for some advice, so the answer is no, I do not have the old ones.
Old 10-23-2013, 01:51 PM   #5
Flyfish1624
Drives: Scion FRS
The springs are not stock
Old 10-23-2013, 01:59 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if KYB made any shocks for you then the GR2's are generally decent OEM replacements for low cost.
Old 10-23-2013, 02:08 PM   #7
Flyfish1624
Drives: Scion FRS
Thanks for the info.
I love the car, just some issue's I was not expecting to have to deal with.
Are after market suspension systems always something you have to mess with and replace?
Old 10-23-2013, 02:12 PM   #8
Stevo22
Stevo22's Avatar
Drives: GR86
You can try and look here Suspension For Sale Forum.
There is a lot of used suspension on there that could be in your range. Also people sell their stock suspension on there pretty cheap. If you don't mind raising the car back up to stock ride height.
Stevo22 is offline   Reply With Quote
Old 10-23-2013, 02:13 PM   #9
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
all suspension systems are something you have to mess with and replace
dampers (shocks) wear out, i'd say your OEM shocks would have had to be replaced every 40-50,000 km anyway
bushings wear out, tie rod ends, ball joints, all these things are consumables and should be replaced at set intervals
no different than after-market
Old 10-23-2013, 02:25 PM   #10
If you want something cheap and fast tomorrow, I bet you could score a complete assembled stock strut + spring + topmounts package from someone that went to coilovers. It will ride and probably handle better than what you have on their now (crappy coilovers).
Since you don't have the stock struts, don't bother with the Konis since you need the stock struts to cut up for the inserts.
Bilsteins are very good. You'll still need springs, top mounts, and a few other bits though, so finding a used stock package for cheap isn't a bad idea to grab all that. Or, we can get all that stuff and get you on some good mild drop performance springs...
- Andy
Old 10-23-2013, 02:27 PM   #11
Flyfish1624
Drives: Scion FRS
I definitely understand about replacing wear items. I just never have replaced shocks on a car with less than 5K miles.
I appreciate the feed back from everyone. Not knowing a lot about cars, I was nervous to post, but y'all made it pretty painless.
next for this car is exhaust and supercharger!!!
Old 10-23-2013, 02:37 PM   #12
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so why are you looking at replacements so early? are your oem's leaking?
Old 10-23-2013, 02:40 PM   #13
Books
Books's Avatar
In that case, I'd go searching around the classified for stock suspension. I'm sure you'll be able to find a good deal there
Old 10-23-2013, 03:20 PM   #14
No KYB shocks for this car yet.
He bought his car used and it came with crappy leaking coilovers.
No, but there is some crap out there. A good quality system will last as long or longer than OEM. Height adjustable coilovers generally require a little more attention, but only crappy ones will blow and leak like yours did within 5k miles.
- Andy
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
FS OEM SUSPENSION! Scalzo Canada Classifieds 0 04-11-2013 12:48 AM
KW suspension jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-13-2013 12:38 AM
Need some suspension help JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 01-19-2013 03:02 PM
Suspension Toyobaru808 Hawaii 14 10-17-2012 11:46 PM
