Old 10-22-2013, 06:15 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
RT700 Brake Fluid
So just got my shipment of RT700.
Thanks @CSG Mike ! I will be putting this in in the next couple weeks and get a review up. Probably try a staged approach. First just a bleed and this fluid. Then add some new stoptech pads i got, then after add some brakelines, or vice/ver
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
CSG Mike (10-22-2013)
Old 10-22-2013, 06:18 PM   #2
Looking forward to your feedback!
We're still working with Torque to get them end user feedback, so please tell us everything, including the thing you DON'T like.
Old 10-22-2013, 06:45 PM   #3
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
You can save your precious brake fluid by swapping out the lines first.
Anthonytpt is offline   Reply With Quote
The Following 2 Users Say Thank You to Anthonytpt For This Useful Post:
CSG Mike (10-22-2013), gdrider77 (10-22-2013)
Old 10-22-2013, 06:56 PM   #4
gdrider77
gdrider77's Avatar
True...That actually might be a better route. Put on the lines first. Test with stock fluid....
Then flush with new RT700.
I would prefer to drain/flush and put new lines on all at once, but then the feedback would be skewed as the lines will most likely influence the feel of the new fluid, and will be hard to differentiate.
So a bit slower process, but will have a bit better results....
Now to find some lines...and possibly speed bleeders.
Old 10-22-2013, 07:44 PM   #5
We have some lines in stock...
Old 10-23-2013, 11:06 AM   #6
Anthonytpt
Anthonytpt's Avatar
I got my front and rear Spiegler lines from @CounterSpace Garage. I'm currently running RBF600, but will probably switch to RT700 when I get the AP Racing sprint brake kit. Nice build you have going there!
CSG Mike (10-23-2013), gdrider77 (10-25-2013)
Torque RT700 - DOT 4 Racing Brake Fluid - Review CounterSpace Garage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 121 06-05-2023 09:23 PM
CounterSpace Garage - Authorized Dealer - Torque RT700 Racing Brake Fluid CounterSpace Garage Announcements, Contests, Giveaways 0 09-26-2013 07:33 PM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 03:20 PM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 07:10 PM
