Old 10-18-2013, 05:39 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
question about motion ratio
so, if I understand this correctly, since our front is a McPherson set up with the strut directly over the front wheels vs the rear double-wishbone set up which have the struts a bit inward from the wheels, our car is generally known to have a ratio of 1:0.75 from front to back? but what about the spring height on the front vs the rear? since the rear springs are a lot shorter, doesnt that negate the inward positioning of the spring and damper, which actually make the rates close to 1:1 or does spring height not play a role in motion ratio? maybe having the engine and transmission in the front which is a big portion of the weight on the car is a reason to have more suspension travel with longer springs, but I`m just curious if spring height has any effect on the motion ratio. please enlighten the noob thank you.
mokinbird87 is offline   Reply With Quote
Old 10-18-2013, 08:13 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
MacPherson struts generally have motion ratios in the 0.9 - 0.95 range. I suspension model I made based on unverified FR-S/BRZ geometry yielded 0.925 for the front struts.
Spring height doesn't influence motion ratio (though motion ratio will influence spring height indirectly)
With a higher motion ratio, the spring needs to have a greater range of travel, hence the spring is generally longer. That's the relationship. It's not as if the longer spring height give a higher motion ratio.
mokinbird87 (10-19-2013)
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 10:44 AM
FR-S Gear Ratio Comparison SpeedR Engine, Exhaust, Transmission 36 02-25-2016 09:34 AM
Rear End Ratio White64Goat Engine, Exhaust, Transmission 6 07-07-2012 11:37 PM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 02:23 AM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 02:40 AM
