Old 10-17-2013, 08:02 PM   #1
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
New Zeek Snorkel Systems from Japan
Available in FRP fiberglass or CF Carbon Fiber
Options: Sound Tube Extra
Here is a new product Zeek that we are carrying from Japan. Air duct for FR-S / BRZ routes fresh, cold air to the stock intake box by collecting air from the grill of the front bumper and directing it over the radiator and into the intake box. This prevents the intake from ingesting hot engine bay air and ensures the engine operates at peak efficiency with the best intake air temperature possible.
There are many design considerations when developing an air intake system for street and race applications. The process is complex when peak HP numbers are not the only goal; a properly designed system will maximize torque and power throughout the RPM range. Consideration should be given to system volume, air inlet temperature, filter construction, sound and wave characteristics, system weight, and final fitment. Zeeks High Performance Intake Systems incorporate all critical design criteria and as a result they fit perfectly, provide maximum torque and horsepower across the entire RPM range, and allow the driver to experience the engine note without being overpowered by extremely high sound levels.
(DYNO SPECS)
Evasive Motorsports is offline   Reply With Quote
The Following User Says Thank You to Evasive Motorsports For This Useful Post:
BRZ68 (10-17-2013)
Old 10-17-2013, 08:26 PM   #2
bear89103
Old Fart
bear89103's Avatar
Price?
Project Panda86 Journal -
bear89103 is offline   Reply With Quote
Old 10-17-2013, 08:33 PM   #3
Evasive Motorsports
Originally Posted by bear89103 View Post
Price?
http://www.evasivemotorsports.com/mm...-INTAKEEXHAUST
Pricing is up Phil!
bear89103 (10-17-2013)
Old 10-17-2013, 09:25 PM   #4
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Would these be compatible with the AFE Takeda Type 2 intake that requires the removal of the stock snorkel?
Wise is offline   Reply With Quote
The Following User Says Thank You to Wise For This Useful Post:
NoFear99 (10-20-2013)
Old 10-17-2013, 09:54 PM   #5
JETRED
JETRED's Avatar
Drives: Unicorn
Is there an option with a snorkel delete?
JETRED is offline   Reply With Quote
The Following User Says Thank You to JETRED For This Useful Post:
Evasive Motorsports (10-22-2013)
Old 10-18-2013, 01:52 AM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Sound tube thinggy?
Really? meh
Old 10-18-2013, 01:22 PM   #7
DarkCard
Drives: Asphalt Scion Frs 6MT
interesting
DarkCard is offline   Reply With Quote
The Following User Says Thank You to DarkCard For This Useful Post:
Old 10-20-2013, 10:58 PM   #8
ft86me
ft86me's Avatar
Drives: 2013 FRS
Curious if this would benefit us vortech guys. Wonder if this would enhance the flow without getting in the way of the intercooler as much. Opinions ??
ft86me is offline   Reply With Quote
Old 10-21-2013, 12:32 AM   #9
Kakawate
Man-ape
Kakawate's Avatar
Drives: 2013 Buddy Club Scion FR-S
Evasive I want this like this week! Are they in stock? I'm in SoCal! Pm me please
Kakawate is offline   Reply With Quote
Old 10-21-2013, 01:49 AM   #10
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Requires removal of the bumper foam???
Kostamojen is offline   Reply With Quote
Old 10-21-2013, 02:14 AM   #11
humanshield
Drives: bucket
couldn't find any info about the option to eliminate the sound generator? i feel the carbon intake tube would keep cooler than an aluminum one but i don't need the sound generator to stick around. any info?
humanshield is offline   Reply With Quote
The Following User Says Thank You to humanshield For This Useful Post:
Muaddib (08-04-2014)
Old 10-21-2013, 02:25 AM   #12
Kakawate
Man-ape
Kakawate's Avatar
Well the foam is a shock absorber and helps the from fascia hold shape from flex under high speed I'm sure but I'm sure you can fabricate around it? It's just foam.
Old 10-21-2013, 12:00 PM   #13
brz_star21
Drives: DGM BRZ
The sound generator tube delete should be an option available. I know this because Sunline Racing has this as an option for their intake snorkel and it's the exact same thing. FRP or CFRP versions. Whether Zeek makes these products for them I'm not sure. Not sure if @EvasiveMotorsports has them on option for order without it?
brz_star21 is offline   Reply With Quote
The Following 2 Users Say Thank You to brz_star21 For This Useful Post:
humanshield (10-21-2013), Muaddib (08-04-2014)
Old 10-21-2013, 12:24 PM   #14
humanshield
Drives: bucket
i assumed there would be an option but none of the photos or info confirm this. don't you have the Zeek intake manifold cover? i could have sworn on instagram i saw something carbon under the hood...
Zeek - CF intake tube and snorkle *KID* Engine, Exhaust, Transmission 11 10-17-2013 10:56 PM
Best alarm systems? normanb21 Electronics | Audio | NAV | Infotainment 4 05-24-2013 02:19 PM
Exhaust Systems hunter3232792 Engine, Exhaust, Transmission 23 12-10-2012 06:14 PM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 11:31 AM
