Drives: 2013 Raven Black FRS
2JZ
Found a 2jz-ge engine today. Good thing is, found it in my sisters GS-300. And she is willing to trade me the car for $1500. Is it worth it? Has anyone done an 2JZ engine swap?
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
Drives: for the sake of driving
Unless you find a 2jz-gte bottom end, swap the vvti head from the 2jz-ge onto it, and turbocharge, it is definitely not worth it. But at that point you might as well put the money you would use to buy the car towards a 2jz-gte longblock.
'13 Argento FR-S
| The Following User Says Thank You to SportInjected For This Useful Post: | Ammonia (10-18-2013) |
Boosted
Drives: Not a supra....yet
2 wheel member
Drives: JZA80, 997.1, Taco
No
aka Mark@STILLEN
Drives: 1991 Toyota MR2 Turbo, 2000 BMW E46
What is your budget for this proposed swap?
Pegasus White
Drives: 86
yeah so you buy the 2jzg(none turbo)e for 1500 how much you got left to turn it into a 2jzgte?
Than how much you got left after that to put it into your 86/BRZ?
Driving: Pegasus White Manual GTS 86.
Drives: brz
Might as well save up more money and get a 2jz from Japan with the stock piles of engines they have. Dont see why people would do an engine swap unless if they blew there motor or if there motor is up there in age which is impossible since this cars still new.
Well, Figured by the time I've Turbo'd the fa20 engine and had it like I wanted it, I would have spent close to $7k having bought, installed, tuned, dyno'd, plus additional parts (oil coolers, oil catch cans, etc) by that time I could have gotten the 2JZ engine and taken my time and built it in my garage and had it ready to drop in completely built.
I'm not in a rush to replace the Fa20 engine, but here is a 2JZ engine sitting in my sisters drive-way that I could take possession of and tweek and have it ready to drop in for more power. The Fa20 engine is weak. Car like the FRS should have came stock with way more rwhp. I would have thought more like 250 rwhp. I love my FRS. But I want more power. And if I'm going to have to turbo and build stock engine to get that, why not just use a engine that I can take my time and build... Thats what I meant when I asked was it worth it. Not to swap out tomorrow...
#9 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
50% more HP and 45% more TQ over stock with excellent reliability, near silent operation and CARB legality should suffice? |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | ravenblackfrs (10-17-2013) |
#10 |
Drives: Sterling BRZ Ltd
Im all for engine swaps in new cars, only problem is depending on the state keeping it street legal can be complicated.
#11 | |
#12 | |
Drives: MkIV Supra & Evo X
http://www.jdmenginedepot.com/jdm_en...ess_JDM_2JZGTE If you used your sister's Aristo you'd still need a turbo kit ($2000-$4000). Don't pull the trigger on any big purchases until you've laid out *exactly* what you need for the whole conversion. I spent $250 to get an Aristo bottom end (from the junkyard on-base, much cheaper than a local-owned one) for my Chaser's 1.5JZ swap. I still expect to spend ~$7k to complete it the way I want (twin scroll ball bearing turbo, dual waste gate manifold, GM LQ9 Coils, Tomei cams, 1000cc injectors, Megasquirt engine management).
1994 Toyota MkIV Supra (project car)
2007 JDM Mitsubishi Exo X GSR-SST (Daily driver) |
| The Following User Says Thank You to Noble713 For This Useful Post: | hmong337 (10-18-2013) |
#13 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I will agree with the op on one thing. The fa20 is a weakling and the frs needs at least another 100hp. You're gonna spend a bunch to fully build the stock 4 banger when you can probably have a 2jzgte for just a a bit more. I've also thought if ever my fa20 kicks the bucket, I'd dump it for an lsx or 2j. Would make for a wild ride!
But my biggest concern would be upsetting the balance of the car so logic tells me to keep the boxer in the car. Just build and turbo the piss outta the FA.
| The Following User Says Thank You to hmong337 For This Useful Post: | Team STILLEN (10-18-2013) |
#14 | |
Mark @ STILLEN
Drives: 2015 Subaru BRZ
I do think the car needs more power also, it might be prudent to just spend the money on either building the motor and going with FI (turbo or SC) or waiting for someone to start swapping in STi Motors. What kind of power are you wanting in the car?
