Drives: WRB LMTD '13
Reuseable TPMS valve kit
Are they reuseable? Also, are they universal? I'm getting the valve kit to be installed with tpms sensor. Got a new set of wheels last night.
Thanks Are these correct way to install them? America Tire want to charge me $5 for the installation. Please help me out. Thanks. ![]()
Drives: 2013 BRZ Limited - WRB, MT
i got the tpms from tirerack and have since moved them to different rims. These were movable no problem without a rebuild kit. they just unscrew and screw back together
The sale tried to rip me off $7 each. He told me they were not reuseable. I'm pretty sure they are.
Drives: Scion FR-S Asphalt AT & XB
It's called TPMS service pack. They cost around $3 each. Reason why you should change them to keep the tpms sealed. Its better to change then risk the air seeping out and causing damage to the tire because of low pressure. If you don't you can reuse but there is a chance something might go wrong. Yes that the correct way to install them in the pic's you have ..... need to torque them at 36 inch pounds not ft pounds ......... if you don't they are going to seep. Good Luck
Part # if you need it is: Dill 1100 |
#5 | |
#6 | |
VTECLOL
Drives: 2011 STi & 2013 F150 SVT Raptor
follow me on Instagram @wlwarfield
OFFICIAL Texas BRZ, FRS, GT86 Facebook Page OFFICIAL NM86CLUB Facebook Page 2011 Subaru Impreza WRX STi sedan 2013 Ford F-150 SVT Raptor |
My tires were only 1500. Removed the tpms for after market wheels
Sent from my SGH-T999 using Tapatalk now Free
America Tire wants $7 each and $5 labor to install. I told the guy that Id do that by myself. It is BS. If I know $3each, Id do that instead.
The only part might not be reuseable was the rubber grommets. I have read that from forums and honda also advised not to reuse compressed grommets.
| PCV valve leaking? | jamesm | Forced Induction | 24 | 12-25-2014 06:38 PM |
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 08:11 AM |
| FS: Fumoto quick valve | Laika | Engine, Exhaust, Bolt-Ons | 1 | 01-08-2013 01:51 PM |
| Cheap Alloy non-TPMS tire valve found | bpracer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 12-08-2012 09:28 AM |
| Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? | Ahz | Issues | Warranty | Recalls / TSB | 9 | 11-06-2012 08:25 AM |
