Drives: Subaru BRZ Limited
MAP bar to PSI?
So trying to determine a few things on my car, most notably my actuator spring pressure and my boost gauge accuracy. I just put a new actuator on, that is suppose to be 8psi.
I uploaded a log with this post... At max looks like my map reading is 1.25bar. How does this translate to psi? Converting this gives me 18.13psi, which i know is not correct. Using the info from this site....boostsource and this formula... Absolute Pressure (psia) = Gauge Pressure (psig) + Ambient Pressure (psia) That would then mean.... 18.13 - 14.7 = 3.43psi? Thing is my gauge is reading around 8-8.5psi under full boost/WOT....AEM failsafe... My old actuator at WOT full boost would read about 6psi..... This new one is reading at 8-8.5 or so at WOT So now really confused. Is it possible i setup the preload on the actuator arm wrong? Maybe thats causing the 8.5psi vs the 8psi, or is that small fluctuation acceptable. But still wouldnt account for the weird datalog on the MAP sensor... Any input...am i reading something wrong in my logs? LOG HERE Thanks all! Last edited by gdrider77; 10-06-2013 at 06:16 PM. |
are you using the stock map sensor? it has limited range, mine maxes out around 5psi.
That Guy
Drives: 2013 asphalt FRS MT
^^That was my first thought to.
#4 | |
3bar map sensor. |
maybe it's not scaled properly? if you can view your rom it's pretty easy to tell.. if the map scale values are 4.834/-2.901 it's still scaled for the stock sensor. you'd probably get a cel though for high or low input if that were the case, but who knows?
#6 | |
View my rom, do you mean like in ecutek?? |
Well, i can ask my tuner tomorrow, he is working on the car in the afternoon, so hopefully we can get it all worked out.
Mr. Cranky Pants
Drives: 2013 Argento FR-S
You're in Denver? Atmospheric pressure there is not 14.7. It's more like 12.
But it does look like your MAP scaling has some issues. |
#10 |
yeah in denver. So would that mean i subtract 12 and not 14.7?
#11 |
Mr. Cranky Pants
#13 | |
#14 | |
I Love custom Turbo kits
Drives: Limited BRZ
Abs. Bar *14.5- (Ambien Pressure) Usually its Abs. Bar*14.5-14.7 (In your high altitude case, that might be ~12 instead of 14.7). It seems your MAP sensor might not be properly calibrated. I doubt your Boost gauge would be 8 psi off.
