Old 10-04-2013, 05:01 AM   #1
OakmanSmalls
Drives: 2013 DGM BRZ
Looking for better turn in (drift)
Looking to see what people have done to increase turn in/ initiation of the drift. I notice that I push a bit when I don't use the ebrake to initiate. I know camber bolts and neg camber in the front will help. Curious about sway set ups and anything else people have done.
My current set up is
Stock strut w eibach sportline (1.4" drop)
Stock wheels w 20mm spacer
OakmanSmalls is offline   Reply With Quote
Old 10-04-2013, 08:15 AM   #2
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Front camber bolts and front antidrive caster kit will solve alot of problems. Both are fairly cheap
Ryaquinn is offline   Reply With Quote
Old 10-04-2013, 08:59 AM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
A little bit of front toe-out will improve turn-in as well.
Old 10-04-2013, 12:48 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Serious question: how will camber bolts and negative camber help? I think you're going about this the wrong way.
To improve turn-in you need to run more toe-out in the front. Camber may feel like it improves your handling response, but it won't solve the problem you've posed.
One thing I've learned over the years is, if it's simply a matter of "feeling" when you go into/out of a turn, toe is the easiest way to change it up. I only change up caster/camber when I run out of other adjustment options.
Feel free to search the web for info on this topic. Here's a good overview:
http://www.ozebiz.com.au/racetech/theory/align.html
-alex
Old 10-06-2013, 02:16 AM   #5
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
You want more negative front camber for drifting. -3 degrees at least. Camber plates will get you there.
Get coils and LCAs and watch the magic happen.
/thread
TylerLieberman is offline   Reply With Quote
Old 10-07-2013, 04:27 PM   #6
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Alignment parts will definitely help turn in!
Corner3garage is offline   Reply With Quote
**Phastek** Cusco Spin Turn Knob aka Drift Button in Stock (all colors) PhastekSport Interior Parts (Incl. Lighting) 4 09-09-2013 03:16 PM
FS: Cusco Spin Turn Knob Drift Button in Socal mtsui Interior Parts (Incl. Lighting) 4 06-09-2013 10:14 PM
Cusco Spin Turn Knob (Drift Knob) gatorbushmen Scion FR-S / Toyota 86 GT86 General Forum 8 04-29-2013 11:14 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
