Old 10-03-2013, 09:23 PM   #1
BlackyRose
Drives: 2013 Raven FR-S
Air filter diy quick help needed
Just followed the diy for an air filter install and even though my silver clamps close easy (the diy said if this happens you have a good seal) I still have some of the polyurethane showing across the top of the seal.
I am using the trd filter which is similar to the k and n.
Can someone conform that showing a little polyurethane is ok or should I see a perfect seal around the entire 4 corners of the air box. Just took it out for a spin and it felt great!! Just a little concerned
BlackyRose is offline   Reply With Quote
K&N Drop-In Filter (Quick Impressions) xcelir8brz Engine, Exhaust, Transmission 83 03-25-2015 09:54 AM
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 06:59 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 11:04 AM
MOD's Needed. Help Please! GT-ROKIN Cosmetic Modification (Interior/Exterior/Lighting) 17 10-06-2012 02:18 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
