Old 09-28-2013, 03:19 AM   #1
retrosmiths
Drives: Scion FR-S Whiteout
FR-S DRL Prototype (UPDATED - Installed!) [56k warning]
UPDATE 2: Installed!
More pictures of the faux-86 DRLs installed here! (Dropbox album)
@Guff
@DaJo
@boredom.is.me
@indesign
@DIM
@soundman98
UPDATED: Prototype, Mark I
This is a prototype I created today, something to test if this is a good idea.
I painted the bottom half of the chrome assembly satin black. I did not paint the high beams because I want to keep the shape of the remaining chrome part, like a sharp, sideways teardrop. I will also be replacing the projectors with better ones, but for now this will do.
Now that I can see where the LED strips will be, I think there is enough space to put in two LED strips, one white and one amber, and utilize a switchback circuit so that the amber will blink in tandem with the signal lights (the white strips turned off while the amber strips are on).
Thoughts?
Well, another project of mine has officially started tonight. I want to add DRL strips to the FR-S headlights, but I don't want to just stick LED strips to the outside where it meets the fender because it will look cheap and effortless. No, I want to do something that looks OEM/JDM (86/Series 10 headlights) but even better.
  • The LEDs should be as bright as the JDM, or brighter, and should point outwards.
  • I want to use the strips as part of the turn signals. They should be white in normal mode and amber/yellow in blinker mode. Kinda like switchback bulbs. I might have to use two pairs of strips for this.
  • I don't want to deviate too much from the chrome look, but I want to paint the bottom part of the chrome assembly satin black. This means precise application of painter's tape to mask off the other parts.
  • Projector retrofits are not included for this run, although I am considering getting a Mini H1 6.0 and hacking the TRS adapters to fit them. But...
  • Budget is tight.
LED choices:
I'm was fascinated by TRS's xB LED strip (they are super bright and you won't see much gaps between the LEDs unlike most strips), but they are out of my budget ($25/pair for 3", $50/pair for 6", $75/pair for 12").
Next, I tried SuperBrightLEDs High Power Flexible Light Strip. I have a pair from a discontinued project. They seem to be fairly bright and solidly built. Here are some initial pics:
White LEDs always look yellow when turned off:
They look way brighter than this shot, my camera is just crappy at low-light:
How I want it to be placed (ignore the black/red paint job, it's my prototype headlight piece with around 200 coats of paint):
And this is how it will look like if I just stick the LEDs in the gap between the headlight and the bumper (which might actually work for waterproof, side-emmitting LED strips, but still....ugly):
Now, I'm deciding on whether to order the strips in black/amber or in white/amber, but it depends on how I want to paint the chrome part.
Thoughts?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 09-28-2013, 04:36 AM   #2
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Not bad, looks pretty cool. Fairly OEM too! If the LEDs themselves were larger, it would probably look even better!
- The Ancient BRZ Sacrament
by Zaku
Old 09-28-2013, 04:40 AM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
IMHO, these strips are too thin to look like OEM.
Also, I see too many of these LED strips done by people and they all end up having a couple or a few LED's in between that does not work properly after a while...
Leaving them with even bigger blind gaps.
These are just not reliable enough to be put inside a housing. (But even worse if left it stuck on the outside) Again... IMHO, which is only worth about 2 cents.
A+ for effort though!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 09-28-2013, 12:29 PM   #4
retrosmiths
Oh, in the last pic, the strip looks thin because I wedged it there facing downwards toward the headlight.
2013 Scion FR-S
Old 09-29-2013, 01:22 AM   #5
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I did that with some purple strips I had laying around. I later thought it was pretty ricey. I already have switchbacks, so I was just going to do turn signals.
I can post pics of the purple if anyone is interested.
Old 09-29-2013, 01:55 AM   #6
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
great idea! however i think the appeal with jdm/10-series drl's is the actual housing the led strip is in, because it creates a mean eyebrow look whether the lights are on or off.
Old 09-29-2013, 02:04 AM   #7
retrosmiths
Yes, pics please!
I'm actually planning to have a metal base for the LED which will look like that eyebrow that you speak of.
2013 Scion FR-S
Old 09-29-2013, 02:16 AM   #8
boredom.is.me
Custom User Title
The final goal was red, but you can see just how quickly this was becoming a bad idea. I personally think there would be too much white light from the headlight area if the strips are white.
Sent from my iPhone using Tapatalk - now Free
Old 09-29-2013, 02:30 AM   #9
m.box.design
Yes, pics please!
Nice! I'll continue saving towards my 10-series lights fund until something more interesting arises.
Old 09-29-2013, 03:01 AM   #10
retrosmiths
Attachment 52510
Attachment 52511
I see that you put the strips outside the headlight, and not facing forward (?). It's also nearer the top near the bottom.
I plan to put mine in the same spot as the 86/10, with the LEDs facing forward as to not highlight the projector housing.
2013 Scion FR-S
Old 09-29-2013, 03:06 AM   #11
boredom.is.me
Custom User Title
You are correct. It was not facing forward as it wasn't meant to. It does indeed highlight the housing. It is also further up for the reason that it can not be seen at all when not on.
Old 09-29-2013, 04:02 AM   #12
retrosmiths
Yeah, I tried the same:
But it just doesn't look right.
I'm also having second thoughts on including another strip to act as the signal light. Reason is, two strips might be too wide, and since they don't connect all the way to the sharp end of the headlight, it will look weird having that angle and space where the strips end.
Not to mention the wiring complexity.
Overall, I just want to keep it simple and clean.
2013 Scion FR-S
Old 09-29-2013, 12:13 PM   #13
DIM
Cool concept, but I agree with Guff. Some bigger LED's would make it look alot better.
DIM is offline   Reply With Quote
Old 09-29-2013, 04:40 PM   #14
m.box.design
would a plastic housing for the LED strip be a viable solution? That is, illuminating an 'eyebrow' housing.
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 09:36 PM
P&L Header prototype Hawaiian Engine, Exhaust, Transmission 388 05-31-2013 01:50 PM
WGP Looking for a BRZ For LS Swap Prototype Doug@WGP Announcements, Contests, Giveaways 25 10-10-2012 05:20 PM
Different wheels on the prototype ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-20-2011 05:00 PM
Wheels on the Prototype joshuo Scion FR-S / Toyota 86 GT86 General Forum 13 11-03-2009 07:37 PM
