Old 09-26-2013, 04:16 PM   #1
swe-gt86
Drives: Toyota gt86
Visconti e85 tune logg! HELP!
Hi guys im really worried about my car since its been acting really strange and start throwing a engine code for bad coil pack. Please anyone can take a look at my logging did some 4 gear pulls at the end of it.
swe-gt86 is offline   Reply With Quote
Old 09-26-2013, 04:17 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
What engine code is it throwing (number)
Old 09-26-2013, 04:22 PM   #3
fenton
How do you get this graph in ecutek?
Do you have to have a Race Rom tune? or is it just a function of the ecutek software.
Thankxs,
fenton is offline   Reply With Quote
Old 09-26-2013, 04:24 PM   #4
Sportsguy83
Drives: Limited BRZ
Thankxs,
You do a Log, finish the log, open it up via file, open log and select Time Graphs on the top.
Old 09-26-2013, 04:27 PM   #5
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
How long was that log?
The knock events didn't look terrible I thought. It would help to see fuel trims and so forth.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-26-2013, 04:31 PM   #6
Sportsguy83
Drives: Limited BRZ
Looking at the time axis label and the last one being at 800000 ms, that is 13.3 minutes so a bit more than 13.3 minutes.
Old 09-26-2013, 04:43 PM   #7
feldy
feldy's Avatar
He had 7 knock events over 13 minutes or so. I had about 17 or so over 30 minute cruise around town and what not. mostly -1 knock. But I did have one instance that it hit -3 and once that it hit -2. Never once did the IAM Value drop infact it kept rising. So my theory and I'm still waiting on @FA20Club.com to respond to my logs that it wasn't real knock. It was picking up bumps in the road ect and reporting it but the knock sensor was not seeing enough to pull timing?
Old 09-26-2013, 04:45 PM   #8
swe-gt86
Drives: Toyota gt86
This car is NA e85 and code is P0351... hope my injectors are okey...
Old 09-26-2013, 04:56 PM   #9
swe-gt86
Drives: Toyota gt86
Here comes a better picture..
Old 09-26-2013, 05:00 PM   #10
swe-gt86
Drives: Toyota gt86
i have been little worried.. sometimes especially now it loose alot of power due to missfires and slip light traction blinking and engine light comes on...
Old 09-26-2013, 05:15 PM   #11
feldy
feldy's Avatar
Get the e85 out of the car. Flash back to a pump gas map or stock. Drive for a few days see if anything feels better. If you are getting the check engine lights slip lights ect that wont turn off you may want to go to the dealer.
Old 09-26-2013, 05:15 PM   #12
FR-S Matt
He's heating up!
Old 09-26-2013, 06:17 PM   #13
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
40 degrees of peak timing at WOT is a bit excessive IMO...not that it is necessarily causing your issue but we stopped making power way below that on e85.
Xero-Limit is offline   Reply With Quote
Old 09-26-2013, 07:51 PM   #14
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Upper right hand corner
448hpsti is offline   Reply With Quote
knock knock! who's there?, looks good, viscan't tuning, visconti bonfire special, viscontifried, viscontinued, what is knock correction
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
Visconti Tune STG 1 Pump Gas Help Cal3000 Engine, Exhaust, Transmission 7 05-05-2013 08:36 PM
Members with Visconti Tune JDKane527 Southern California 15 04-26-2013 02:56 PM
CEL with Visconti tune tjdiz92 Issues | Warranty | Recalls / TSB 44 09-16-2012 04:04 AM
