Old 09-22-2013, 11:09 AM   #1
JayV
JayV's Avatar
Drives: Subaru BRZ
Question Installed Tsudo catback NEED Help!!
So the other day I received and installed my studio catback. I had no problems with the install except that the fitment of the tips are a little off. One tip is higher than the other and also the left tip sticks out further than the right.
My question is .. With the stock front pipe do you use the donut gasket or the flat gasket.??? the reason why im asking is because the donut gasket makes the exhaust separate from the front pipe about a quarter inch or less. I will like someone to confirm this for me before I go and jack up my car again. Thanks in advance!!
Other than that the exhaust sounds great!!! Nice deep tone even with the stock front pipe.
JayV is offline   Reply With Quote
Old 09-22-2013, 11:13 AM   #2
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by JayV View Post
So th e othere day I recieved and installed my tsudo catback. I had no problems with the install except that the fitment of the tips are a little off. One tip is higher than the other and also the left tip sticks out futher than the right.
My question is .. With the stock front pipe do you use the donut gasket or the flat gastket.??? the reason why im asking is because the donut gasket makes the exhaust separate from the front pipe about a quarter inch or so. And I will like someone to confirm this for me before I go and jack up my car again.
Depends on the flange the tsudo has... if the tsudo is a bellmouth like the stock catback then you use the doughnut gasket, if the tsudo flange is flat with no bell mouth then you use a regular gasket.
Old 09-22-2013, 11:16 AM   #3
jpit
Drives: Subaru BRZ
Use the doughnut gasket. It will seal the connection and allow a little bit of movement.
jpit is offline   Reply With Quote
Old 09-22-2013, 02:48 PM   #4
JayV
JayV's Avatar
Drives: Subaru BRZ
Thanks guys.! I need to definitly buy that front pipe i guess if i want to fix my problem.
Old 09-22-2013, 03:23 PM   #5
mad_sb
Seriously doubt that. See if you can "adjust" the hangers and any joints to get the tips lined up the way you want. Adding a front pipe will not change a bent hanger or improperly aligned joint.
Old 09-22-2013, 05:01 PM   #6
invaliduser
Drives: 2017 86
I used hangers from autozone to get my tips aligned properly on the tsudo catback.
invaliduser is offline   Reply With Quote
Old 09-22-2013, 05:13 PM   #7
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Loosen the connections, align the system, then tighten front to rear. Might need some new exhaust hangers to tighten up the fitment.
mwjcyber is offline   Reply With Quote
Old 11-05-2013, 11:00 AM   #8
frstn
frstn's Avatar
Drives: 2013 FRS
I'm having the same problem with the tsudo catback. The left muffler tip sticks out more than the right. Anyone know which exhaust hangers will make them even up? It's a tough life being a perfectionist lol I just can't leave it like that
frstn is offline   Reply With Quote
Old 11-05-2013, 03:21 PM   #9
invaliduser
Drives: 2017 86
Mine still aren't perfect. But I bought one of each size AutoZone had in stock. I'm not sure what combination I ended up using.
Sent from my HTC One using Tapatalk
Old 11-05-2013, 03:26 PM   #10
bakerr6
Drives: 2013 raven black fr-s
btw, if you are using the j2 front pipe, I used the flat gasket, no donut, and I'm not getting any leaks. It's really up to you though
bakerr6 is offline   Reply With Quote
Old 11-05-2013, 03:58 PM   #11
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I have the Tsudo front pipe and catback on its way. I'll let you know how it fits.
Old 11-05-2013, 07:22 PM   #12
invaliduser
Drives: 2017 86
It's a great sounding kit. A more aggressive sounding g35 type of sound. I think you will like.
Old 11-07-2013, 04:28 PM   #13
frstn
frstn's Avatar
Drives: 2013 FRS
I love the way it sounds. I will just have to try different hangers and let you guys know which worked the best for me. boredom let me know if you have the same problem with the fitment
Old 11-07-2013, 04:37 PM   #14
boredom.is.me
Custom User Title
Try bending the hanger on the exhaust itself. I'm not sure if it's possible, but what the heck right.
worse mpg after installing tsudo catback. any ideas? bahanii Engine, Exhaust, Transmission 5 09-21-2013 07:43 PM
FS: Tsudo Dual Burnt Tip catback exhaust + Downpipe frs4mark Engine, Exhaust, Bolt-Ons 4 05-19-2013 06:08 PM
Revworks UEL header, Tsudo catback vids Opposed Engine, Exhaust, Transmission 8 05-15-2013 01:36 PM
Tsudo high flow cat and Tsudo Catback Exhaust ERZperformance Engine, Exhaust, Transmission 5 04-23-2013 02:25 PM
Tsudo high flow cat and Tsudo Catback Exhaust ERZperformance Engine, Exhaust, Bolt-Ons 18 03-21-2013 04:35 PM
