Old 09-18-2013, 04:33 AM   #1
asphaltkyle
asphaltkyle's Avatar
Drives: 2013 BRZ, 2011 M3 Competition
Front driver's side shock angled?
I just installed Hotchkis lowering springs by following the DIY guide on the forums a couple weeks ago. When I was driving today, I heard a clunk and wasn't sure if that was my suspension making that noise or if I ran over something.
So, I checked out my shocks and struts all around and noticed that my front driver's shock is angled more than my passenger side's shock.
Is this normal or do I need an alignment?
I may be imagining things, but my steering feels less tight and responsive.
asphaltkyle is offline   Reply With Quote
Old 09-18-2013, 08:35 AM   #2
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Umm check the top hat bolts to make sure they were torqued down and seated properly. Make sure the springs are seated correctly to.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
asphaltkyle (09-19-2013)
Old 09-18-2013, 12:51 PM   #3
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
When you say angled, do you mean that the lower portion of the damper is sitting more forward than the top? If so, that is caster angle. Not sure why one would be different than the other unless a bushing went bad in the front lower control arm. But I would just double check everything like Feldy suggested and see if you can find anything that looks out of place.
Hope this helps.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
Old 09-18-2013, 02:08 PM   #4
autobrz
Drives: Mazda 3
and yes you do need an alignment after installing lowering springs. your toe will be wacky...
autobrz is offline   Reply With Quote
The Following User Says Thank You to autobrz For This Useful Post:
Old 09-18-2013, 03:31 PM   #5
brz7400
brz7400's Avatar
Drives: Subaru BRZ
maybe if you have camber bolts, it was not tightened enough and ended up being out of set angle and moving back and forth causing clunks?
brz7400 is offline   Reply With Quote
The Following User Says Thank You to brz7400 For This Useful Post:
Old 09-18-2013, 04:09 PM   #6
infinite012
Drives: 13 DGM BRZ Ltd
If a strut is visibly angled (in any direction) more than the opposite side, you have bent something.
In other words, it's totalled.
Bro.
infinite012 is offline   Reply With Quote
Old 09-18-2013, 07:53 PM   #7
asphaltkyle
I think I am good now. I jacked up the front and loosened and retightened the strut tower nuts, the top hat nut, and the strut bolts/nuts to the factory specs.
My car feels normal now, and thank you for all your input.
The Following User Says Thank You to asphaltkyle For This Useful Post:
feldy (09-18-2013)
WTB firestorm front bumper and driver side view mirror kidmex55 Want-To-Buy Requests 0 08-07-2013 11:02 PM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 04:29 AM
FS asphalt driver side front fender Yruyur Exterior Parts (Aero, Lighting, Etc.) 3 02-07-2013 07:46 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 04:15 PM
