Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 09-12-2013, 11:23 AM   #1
Excelerate
Excelerate's Avatar
Drives: Crystal Black BR-Z Limited
Excelerate Performance: Special Install Price on ISC Coilovers for Local Customers!!!
Excelerate Performance is proud to be a shop in the Northeast and we want to help our local customers (CT, MA, NJ, NY, PA, etc) as much as possible. We will be offering the ISC N1 Coilover for your BR-Z or FR-S for $1199 installed plus tax for our local customers. We are located in Branford, which is right outside New Haven, CT.
If you would like ISC's Rear Lower Control Arms along with your coilovers, we will install those for free! Also, First person to come in for the install will receive an additional $50 off.
*Prices do not include CT sales tax, which is only applicable to orders shipped to CT or coilovers that are installed. For those of you who are looking for installation some exceptions and additional costs may apply depending on the condition of your vehicle (Rust, Frozen bolts, Broken components, etc).
There are 2 different variations of the N1 for the BR-Z and FR-S and each variation can be ordered four different ways (Street Comfort, Street Sport, Race Track, Custom). The $1199 installed price is for the N1's with Front Camber Adjusting Pillowball Upper Mounts and Rear Aluminum Upper Mounts. ISC also offers an add on which will include Rear Camber Adjusting Pillowball Upper Mounts as well as the fronts. Those are going to be $1340 installed plus tax
Here is more detailed information on the N1's:
The ISC N1 Coilover Features Include:
  • 32-Step Adjustable Dampening
  • Pillowball Uppermount
  • Piston Rod Design
  • Sports Springs ( Street Comfort, Street/Sport, Race/Track)
  • Ride Height Adjustable
  • Aluminum Bracket
  • Single Cylinder Design + More
Features:
  • 32 Steps of Damper Adjustment
  • Precise control of valving/damping (rebound only)
    Operates smoothly on all road surfaces
    Expansion/Suppression of shock adjustment
  • Camber Adjusting Pillowball Uppermount (Front) and Aluminum Upper Mounts (Rear)
  • Adjustable camber allows more/less on road track for all conditions
  • Piston Rod Design
  • Strengthened steel piston rods
    Meets race/sport standards
Sports Spring
  • Made from high quality SAE9254 steel
  • Tested over 500,000 times on compression inspection with less than 5% deformation
  • Choose from Street Comfort, Street/Sport or Race/Track. Spring rates are as follows for the FR-S and BR-Z: Street Comfort 10/7 Street/Sport 10/7 Track/Race is 12/9. Although Street Comfort and Street Sport have the same spring rates, the valving of the shafts are different between the two setups.
  • Full length height adjustable
  • Pre-load adjustable with separate spring locks
  • High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminum Bracket
  • Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance
  • Specially anodized surface to prevent internal corrosion and surface rust
  • Monotube construction
  • Larger cylinder and piston design to advance driving stability and dexterity
Thrust Bearing
  • Improves steering and creates a smoother ride
  • $55 upgrade included for free on the BR-Z and FR-S
Excelerate is offline
Excelerate Performance: Special Pricing on Stoptech Big Brake Kits!!! Excelerate Brakes, Suspension, Chassis 21 07-08-2014 12:22 PM
Excelerate Performance: Lowest Price on KW V3's!!! Excelerate Brakes, Suspension, Chassis 3 08-28-2013 11:53 AM
Introductory Sale from Excelerate Performance!!! Excelerate Announcements, Contests, Giveaways 5 08-08-2013 11:06 AM
Special Purchase price-TEIN FLEX FR-S/BRZ coilovers Stav Canada Classifieds 5 04-21-2013 05:41 PM
OptionJDM -Cusco Coilover System Special for Canadian Customers! OptionJDM Brakes, Suspension, Chassis 7 07-19-2012 02:49 PM
