Old 09-10-2013, 05:04 PM   #1
Scionshaun
Aloha!
Drives: Whiteout
Exclamation Paintless Dent Removal (PDR) in wisconsin
Hi folks
Got a shopping cart run into the side of my passenger side door.
Anyone ever used pdr to get it fixed? And normally what's the turn around time for this?
Scionshaun is offline   Reply With Quote
Old 09-10-2013, 05:07 PM   #2
Scionshaun
Aloha!
Drives: Whiteout
If anyone has before and after pics please post. I feel sick thinking about it.
Old 09-10-2013, 05:21 PM   #3
KevinBRZ
I got a door ding fixed, and lots of hail damage. For the door ding, I just watched the guy do it. Was about 20-30 minutes. He sticks a long metal pole with a hook on the end, or similar, and just pushes against the metal until it is flush again. There's also glue pull for areas they can't get to. I thought he was going to punch that hook right through the metal since it's so thin. It was flexing like a balloon.
KevinBRZ is offline   Reply With Quote
Old 09-10-2013, 05:40 PM   #4
Scionshaun
Aloha!
Drives: Whiteout
Thanks. It looks flawless though, right?
Old 09-10-2013, 06:09 PM   #5
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
I just got my entire car fixed that way. The results were sweet, one could never tell my car suffered from some bad hail damage. That said, it is not cheap, it cost around $2200 to get my car all fixed up (insurance did cover it doe). It's a good option, to be sure.
SkitterSkotter is offline   Reply With Quote
Old 09-10-2013, 06:10 PM   #6
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
I had a small crease in the driver's door of my Cayman (it kills me how some people aren't careful...), and the procedure was pretty much as Kevin described: hooked metal pole inserted into door via window slot, lots of painful looking manipulation (I was pretty nervous, I have to admit), but at the end of the day, you can't tell at all that there was ever a crease there. I can't argue with the results.
EDIT: Just noticed you're in Boulder too Skitter - who did you go with? I went to Dents By Hand on Arapahoe, and I was very happy with the results.
chrisl is offline   Reply With Quote
Old 09-10-2013, 07:30 PM   #7
Scionshaun
Aloha!
Drives: Whiteout
And it wasn't due to carelessness. These people were jealous. To have that impressions into my door. Thanks guys for commenting. If you folks have before and after pics would greatly appreciate it!
Old 09-10-2013, 07:49 PM   #8
Scionshaun
Aloha!
Drives: Whiteout
Sent from my iPad using Tapatalk HD
Old 09-10-2013, 07:56 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
What ****s, I would surmise this should cost well under $1000, I think one person on here had severe damage on there roof at one point and the only way to do the paintless dent removal on that was to remove the headliner and carefully have the dent remover push back the dent. In the case of the door I believe they will either use the hook maneuver as mentioned before or they will be forced take apart the door trim in order to get to those pinhole like dents.
Old 09-10-2013, 08:00 PM   #10
Scionshaun
Aloha!
Drives: Whiteout
I've got the dent wizard protection. I will keep you guys updated how it works. I'm just so bummed my car got molested today. Just so irritated on how people could be such @$$h0le$!!!
Old 09-10-2013, 09:45 PM   #11
chrisl
I would think it would be a few hundred, yes. My cayman (small crease in the door, as I said, plus a tiny dent above the rear wheel) cost $100, and this looks like maybe 3 or 4 times as much work as mine was.
Also, that sucks. I can't even imagine the feeling walking out to my car and seeing that
Old 09-10-2013, 09:51 PM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
i have the same door ding, let me know how much it costs
Old 09-10-2013, 11:56 PM   #13
Scionshaun
Aloha!
Drives: Whiteout
I will let you know.
Old 09-11-2013, 11:48 AM   #14
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
http://acci-dent.com/
2superblus is offline   Reply With Quote
Dent :( Will paintless dent removal be able to get this out? Greg_Di CANADA 22 08-31-2013 11:22 PM
paintless dent removal jamesm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 08-11-2013 11:15 PM
Good Dent Removal Place in MA? FRiSson New England 10 03-28-2013 07:22 PM
Recommended Dent Removal Shops? tokiokun717 Northern California 3 03-08-2013 12:48 AM
Dent Removal 7thgear Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2012 06:38 PM
