| DIY (Do-It-Yourself) Guides For all DIYs. |
AppRadio 3 Install
kept looking around for a head unit install but couldn't find anything, follow along if you wish for my install, will most likely take course over 2 weeks....however if another install is posted, please let me know too
![]() To start, basiccally just prep work before i mess with the wires, just a quick play around as it's raining outside and dont really have too much time to play with today ![]() 1) I removed the stereo trim panels: ![]() ![]() ![]() Lining up the bracket, turns out it only fits upside down.... ![]() Just curious about the fit...currently driving without that trim piece lol ![]() Installed the front spacers and wires.... ![]()
Reserved
reserved
Drives: 08 4x4 offroad tacoma/ raven fr-s
its not necessary to remove the long dash piece. Just the radio piece itself pops out really easy. That dash install kit is crap. You will have to modify it to work in conjunction with the stock brackets. I took some dykes and cut out some of the plastic to fit around the metal bracket. Also another thing I had to do was make the holes that the screws go into on the appradio bigger. The stock screws wont screw into them. I used a self tappin screw to open up the holes then the stock screws went right in. I don't understand why you have to modify a "stock" replacement part like that but you do. haha
| The Following User Says Thank You to allmotorrex For This Useful Post: | ts87 (09-07-2013) |
i ripped out that long piece just to see what was behind it haha, may actually run a few wires to the glove box that way since its a lot more open, still havnt had time to fully play around, hoping to have this thing wired up tomorrow
![]() The funniest thing i find about the FR-S is that every time i look at another part, its always stamped with Subaru |
so did you ever get it installed?
I got it hooked up, however not fully yet, i am still waiting for my handbrake bypass from ebay, hoping to have it by next week, one its in, i can finish installing, for now, just radio, but looks awesomes so far imo
installed trim pieces for now, till i get my parts: ![]() ![]() Glare actually looks really bad in the pictures however, i didnt have any issues using it while driving |
#10 | |
Drives: 2013 Whiteout FR-S
| The Following User Says Thank You to Ghost 86 For This Useful Post: | charged86 (09-11-2013) |
#11 |
Drives: Firestorm FR-S
Ordered mine two days ago. Sould be here tomorrow. Do you think it would be possible to connect the app radio to an USB input that is there now? I know there is a DIY for that but i didn't know if the app radio would be different
#12 |
You are right. You do have to ground it but it needs to be grounded after the radio comes on. All he needs is a relay. Same style relay that comes in lighting wiring harnesses and stuff like that. $5 at AutoZone. Power goes to the head unit, turns the head unit on first then switches the relay to a ground. It won't work otherwise
| The Following User Says Thank You to allmotorrex For This Useful Post: | ravenblackfrs (09-28-2013) |
#13 | |
So to answer your question further ..... It doesnt appear that an iPod will work without either a USB + head phone jack plugged into it or that 30 pin cable so even if you hooked up that stock USB port then it would only display info but play no sound. What I did think about doin, which I think I'm gonna try, is just powering that stock USB port so that it can serve as a charger. I have a car charger for my phone but it takes up a lot of space in the center console so if I could just plug in a cable to that USB port and charge my phone then that would be very useful for me |
#14 |
Seems Legit
Drives: Toyota
While I don't advocate watching videos while driving in the driver position Pioneer radios have never required additional parts to bypass the parking brake function.
Simply ground the slot next to the mute wire (yellow/black). You can move the mute wire over or just insert a wire into the empty slot and make sure its tight and won't work itself loose over time...bypass done. No additional money squandered on relays and switches. Finished product
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
| Tags |
| app radio 3 |
| Pioneer AppRadio 3 with MirrorLink | Alabang BRZ | Electronics | Audio | NAV | Infotainment | 53 | 06-01-2014 10:22 PM |
| DashCommand, PLX Kiwi 2 WiFi & Pioneer AppRadio | Alfalasy | Electronics | Audio | NAV | Infotainment | 7 | 09-12-2013 01:50 AM |
| Where to install amp in FRS? | mit_peid | Electronics | Audio | NAV | Infotainment | 10 | 03-24-2013 01:01 PM |
| Need help with HID install | ortizwyld | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-21-2013 11:12 PM |
| Pioneer AppRadio | quik1987 | Electronics | Audio | NAV | Infotainment | 33 | 01-23-2012 05:55 PM |
