Old 09-04-2013, 08:29 PM   #1
fitcious
FRS wiring for home link?
Hi everyone,
I know brz has home link as option. Does our scions have the wire for it already or do we need to run a harness. Is it truly plug and play?
Thanks
Sent from my Samsung S4 using tapatalk
fitcious is offline   Reply With Quote
Old 09-04-2013, 08:39 PM   #2
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
As far as I know the BRZ and FRS have the exact same wiring.
The difference is the options . Makes sense to me because they produce the FRZ in the same plant.
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 09-04-2013, 08:41 PM   #3
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
Our FR-S Has All You Need to Connect Homelink PnP
There are a couple DIY discussion threads dedicated just to this topic.
The factory supplied connection harness is already existing on the passenger side of the headlamp - tucked underneath the headliner. Once you reach for the harness and locate the electrical connector at it's end, you can easily proceed to do the install.
Good luck, it's a 10 minutes job.
Zagmeister is offline   Reply With Quote
Home link mirror fell off! aceangel Issues | Warranty | Recalls / TSB 186 08-31-2014 10:17 PM
WTT my auto dim mirror for your home link mirror + cash. Thongpocket Audio/Visual, Electronics, Infotainment, NAV 1 09-05-2013 12:05 AM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-01-2012 11:45 PM
