Old 09-04-2013, 03:44 PM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Removing AC Vents?
Anyone know how to get to the vents? I'm going to be re-doing my interior soon, since I'm running with a red theme. Here's a quick photoshop I've done.
I know how to get the front/radio dash off, and the handles, but I haven't seen a write up for the vents. Any idea?
636 is offline   Reply With Quote
Old 09-04-2013, 03:56 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
They just pull right off. gentle pulling and they will click in and out
btw that looks sexy if you pull it off that way
Old 09-04-2013, 04:41 PM   #3
svodka
Drives: 2013 BRZ 6MT
Yeah, I think there's 3 clips, just use a small flathead with electric tape on it so you don't scratch anything.
svodka is offline   Reply With Quote
Old 09-04-2013, 05:17 PM   #4
636
636's Avatar
Drives: '23 CWP BRZ
Thanks guys, I'm going to be buying the vinyl soon, I'll have pictures up when I'm done! (Will probably be next week sometime)
Old 09-05-2013, 08:20 AM   #5
svodka
You should do the ring around the shift knob too, I think that'd look good.
Old 09-05-2013, 08:24 AM   #6
nalc
Drives: 13 BRZ Limited 6MT GBS
I just think painting interiors in anything that's not a shade of grey, black, or silver just looks terrible, but you might as well do it right.
Stick your finger in the vent, and grab around from behind, and pull it out.
When it's out, there's tabs that you can gently lift to pop the trim ring off of the vanes.
When that's out, if you look at the inside, there are tabs you can gently separate that will remove the silver trim ring from the black trim ring, so you can paint them separately.
nalc is offline   Reply With Quote
Old 09-05-2013, 08:56 AM   #7
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
You just pull the whole vent out then you can see the clips on the sides that hold on the rings. Super easy. Just know that they only go back in one way, keep turning until they pop back in.
jadewbj is offline   Reply With Quote
Old 09-05-2013, 09:38 AM   #8
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
http://www.rallysportdirect.com/2013...FR-S-Base-2.0L
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-05-2013, 01:38 PM   #9
FR-Slide
Drives: 13 Whiteout 6MT
As others have stated, they simply pull out/off.
I just did my interior in white (to color match), for the AC vents, door handles, steering wheel trim, shifter surround, and AC pillars. I originally wrapped everything in a brushed aluminum vinyl, but there were SO many tight compound curves that it just looked bad in some places and drove me crazy. The dash panels and uprights are easy, but the AC trim and shifter bezel suuuuucked. I really wish you luck wrapping those!
Personally, I ended up not liking the white, and have the AUDM black pieces on order from Amayama. The white was too bright/distracting, and conflicted too much with the red/black theme I have with the JPM pieces and stock colors. Hopefully you'll like the red more than I liked the white!
FR-Slide is offline   Reply With Quote
Old 06-24-2016, 05:19 AM   #10
Jackoblee
Acura Vent Slider
Drives: Red Color with Alloy
2 torx jolts on the edge over the HVAC controls. At that point haul the base up and out. There is a spread over the torx jolts, simply pull down on it to expel it and access the jolts.
Jackoblee is offline   Reply With Quote
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright ill roller Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2013 10:49 PM
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents BlueLeader Exterior Parts (Aero, Lighting, Etc.) 0 03-18-2013 02:55 PM
Side vents Boosted Cosmetic Modification (Interior/Exterior/Lighting) 3 03-08-2013 08:14 PM
(CNJ) WTT Red BRZ for FRS vents grst1 NY / NJ / CT / PA 0 12-12-2012 10:40 AM
Want to Trade: My Whiteout FRS Fender Vents for the SWP BRZ fender vents DC-FRS Exterior Parts (Aero, Lighting, Etc.) 15 11-01-2012 11:41 PM
