Old 08-31-2013, 11:08 AM   #1
The RZ Precept
The RZ Precept's Avatar
Drives: Whiteout - FRS/86
DRL LED
This maybe a stupid and obvious question but I need to be sure, do I need a resistor(s) for the an aftermarket Precision LED's high beam DRL? The LEDs operate fine with and without. I know it's ideal to have resistors with LEDs, but will not having it cause long term harm? One of the included resistors is completely unusable.
Thanks in advance.:happy0180:
The RZ Precept is offline   Reply With Quote
Old 09-01-2013, 10:11 AM   #2
Xanzent
Xanzent's Avatar
Drives: 2013 Scion FR-S Asphalt
Resistors are only necessary with blinkers to avoid high-speed or "hyperblink" when using the stock flasher relay.
With DRLs or any other static light no resistors are necessary.
Xanzent is offline   Reply With Quote
The Following User Says Thank You to Xanzent For This Useful Post:
The RZ Precept (09-02-2013)
