Drives: SWP Limited manual BRZ
How similar are all the different carbon parts?
Do I need to buy all one manufacturer in order for all the carbon pieces to "match"? How similar is the carbon for all the carbon fiber part manufacturers such as APR, Seibon, and Rexspeed?
I understand the difference between the dry and "wet" carbon... Also the 1x1 and 2x2 weave... I'd assume doesn't look that similar to each other... Besides that does all the wet carbon look the same so that I could mix and match various brands on my car and it will look "right"? -Ryan S. |
Drives: DGM BRZ
Some factors to consider (among many things):
-Type of part being made or overlaid in carbon might affect the way the weave looks, as well as the direction. For example a carbon mirror might give a slightly different effect because of the contours and direction used compared to a flat piece of a top surface of a bumper lip. -Size of the weave. -Type of weave (i.e. plain or twill weave) -Manufacturer and the process they use to make it. Sometimes even parts from the same manufacturer can vary in look, especially if they're hand-laid. Most times it's best to stick with the same company for the sake of it. Last edited by brz_star21; 08-31-2013 at 07:19 PM. |
| The Following User Says Thank You to brz_star21 For This Useful Post: | Norcalmav23 (08-31-2013) |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
i got a seibon ts hood and a vis racing ams trunk and they match perfect
| The Following User Says Thank You to NYCsubaruBRZ For This Useful Post: | Norcalmav23 (11-27-2013) |
| Any site with a diagram of parts? Similar to realoem.com for BMWs | tracerit | BRZ First-Gen (2012+) — General Topics | 6 | 03-14-2015 11:39 PM |
| FS: JDM parts - TRD Carbon Fiber Tower Bar | pda | Engine, Exhaust, Bolt-Ons | 3 | 03-13-2013 05:24 AM |
| Carbon fiber parts? | Emusoda | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 07-16-2012 05:49 AM |
| Carbon Exterior parts and Lip Kit!!!! | staycrushing | Cosmetic Modification (Interior/Exterior/Lighting) | 74 | 07-15-2012 09:12 PM |
| Carbon Fiber Parts | H8R GTS | AUSTRALIA | 1 | 06-29-2012 06:52 AM |
