Old 08-29-2013, 02:29 PM   #1
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Nut torque for header to block?
Ok so swapping headers and saw I was missing a nut. Anyone have the proper torque for the nuts?
Overland'n'5thGEN is offline   Reply With Quote
Old 08-29-2013, 02:46 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
From the top of my head, I think its ~22 ft/lb. Don't have the service manual handy but I'm almost certain
2013 FRS
Vortech V3 11psi
Old 08-29-2013, 06:02 PM   #3
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
22 is what my Borla instructions said. I did 24
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 09-12-2013, 03:06 PM   #4
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
I found a lot of mis-information in the borla instructions. I used them to aid in my rev works install but they either had a lot of typo's or just didn't know the proper bolt sizing.
I tightened mine up to 22 but I think I'm going to go 24 as well today.
Jaylyons1 is offline   Reply With Quote
Old 09-12-2013, 08:11 PM   #5
AL008
Drives: Celica 04
How important is it to torque up the header bolts?
AL008 is offline   Reply With Quote
Old 09-12-2013, 08:16 PM   #6
nix
nix's Avatar
Drives: AVO BRZ
It's important if you don't want any leaks... then check and retorque them a week or something later after it's fully heat cycled and settled in.
nix is offline   Reply With Quote
Old 09-12-2013, 09:14 PM   #7
AL008
Drives: Celica 04
Based on 22ft lb of torque. It isn't much, so isn't that almost hand tight + max of half a turn more?
Old 09-12-2013, 09:26 PM   #8
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
Proper torque is important so there will not be any warped flanges or leaks. Try to borrow or purchase a torque wrench.
Old 09-12-2013, 10:13 PM   #9
FirestormFRS
Based solely on my own experience with other engines 22lb/ft 30nm seems reasonable. That's a lot more than hand tight + half a turn. Just do em all then go back and check em again. Gasket squish will lower the original torque on the first couple.
I'm not sure why you'd need to go back a week later. I've put on thousands of them over the years and never had one come lose a week or even a year later, that I know of.
FirestormFRS is offline   Reply With Quote
Old 09-12-2013, 10:18 PM   #10
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
22lb/ft then re-torque after a few heat cycles
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-12-2013, 11:19 PM   #11
nix
nix's Avatar
Drives: AVO BRZ
Flange and gaskets can tend to loosen/move around a bit after a few heat cycles.
Which EL Header Correct Torque Dip Best? slava Engine, Exhaust, Transmission 56 02-20-2019 07:50 AM
Block Heaters for those that might need them smbrm CANADA 17 07-22-2014 05:56 PM
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
