Old 08-28-2013, 07:19 PM   #1
s0sl0w
Proud of Boxer
Old fashioned N/A power making... Anyone?
Is anyone doing some of the more "old fashoined" power making for the FA20 or has everyone just jumped on the F/I train. I'm talking about port/polish/port matching, cams, etc.
I'm intensely interested in a lightened up (rotational mass) with a thoroughly groomed powertrain BRZ.
If people are pushing near 200 WHP with bolt-ons + tune I think some good head work could really make the car a stunner and even if you do go F/I afterwards it's just going to make that much more power.
s0sl0w is offline   Reply With Quote
Old 08-28-2013, 07:23 PM   #2
Andy@FA20Club
Drives: FA20Club.com
Cams are the hold up currently -- not available on the market.
Andy@FA20Club is offline   Reply With Quote
Old 08-28-2013, 07:34 PM   #3
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
Have people approached cam makers for N/A parts? Or is the focus on feeding the FI fire right now? Are we just waiting for SEMA/PRI of this year or are they not even that far along in development?
Ignorant to how knocky these motors can be with the stock compression, I would love to see some forged high compression pistons, lumpier camps and ITBs... a boy can dream, right?
DoctorNick is offline   Reply With Quote
Old 08-28-2013, 07:59 PM   #4
jamesm
The closest thing to an NA build worth doing is the innovate kit. As always with these small engines (that aren't Hondas) the hp/$ math just doesn't work for NA. You can make so much more power for so much less money than with FI that is just doesn't really make any sense.
Purists will disagree, but until itbs and cams and all that are available it's not an option, and even when they are it won't be a good one.
Old 08-28-2013, 08:00 PM   #5
Andy@FA20Club
The Cams are complicated to say the least but beleive will see something as HKS is the only one now with the unicorn.
Old 08-28-2013, 08:04 PM   #6
s0sl0w
Proud of Boxer
Taking care of the fundamentals will only make a f/i'd motor that much better. F/I isn't a replacement for a proper internal work.
Old 08-28-2013, 08:10 PM   #7
jamesm
building an engine for na power and building an engine for boost have very little in common, and use very different parts. what works for fi is pretty much the exact opposite of what works for making power na.
if your goal is to make more power, then making it with fi definitely is a replacement for (or alternative to) engine work. of course a built motor and boost is even better, but building your engine for na power today isn't going to help you make power with your fi setup later down the road. you'd end up building the engine twice.
The Following User Says Thank You to jamesm For This Useful Post:
Sithspawn (08-31-2013)
Old 08-28-2013, 08:41 PM   #8
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
There are a few things that benefit both like forged internals and polishing balancing. But yes heads or cams should be designed for either setup not both.
150 lbs of weight loss and +40whp will really change the way this car moves.
Full light weight exhaust, battery, spare tire , seats, brakes, tune.
Not cheap though
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 08-28-2013, 08:44 PM   #9
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
I'd love to lighten up the rotating mass and do whatever it takes to increase throttle response. A little bump in N/A power would be nice too.
Old 08-28-2013, 08:49 PM   #10
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
I would die for a NA FA20 motor fully built to 220+ rwhp with 200+ ft/lb torque and rev to 11-12k rpm
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 08-28-2013, 08:59 PM   #11
Smokinbuffalo
BRZ Owner
Smokinbuffalo's Avatar
Drives: SWP Ltd MT BRZ, Scion xA
Whatever tunes the torque dip out, give me that.
Buy the ticket, take the ride
Smokinbuffalo is offline   Reply With Quote
Old 08-28-2013, 09:14 PM   #12
s0sl0w
Proud of Boxer
Not cheap though
Cams and changing the compression ratio yes but head flow is head flow, flow is good.
Old 08-28-2013, 11:00 PM   #13
Calum
That Guy
Drives: 2013 asphalt FRS MT
Recent work with DI seems to conflict with that. I don't understand it so I'm not even going to attempt to paraphrase it, but from what I've read if you just look for all out flow your gonna have an engine that runs very poorly.
Old 08-28-2013, 11:34 PM   #14
Turdinator
Señor Member
Turdinator's Avatar
My understanding is that there need to be a tumble effect in the cylinder for the fuel to mix correctly. I haven't seen anything about whether this is more of an emissions or economy thing or whether the engine really needs it to run well. But 4 valve per cylinder engines have been utilising air tumble for years. The 2 valve engines use swirl to the same effect. So I am sure the guys that port and polish heads can make it work for us also.
1974 TA22 Celica
2013 86 GT
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-27-2013 12:49 AM
Legacy In The Making? Texas BRZ Tracking / Autocross / HPDE / Drifting 23 12-11-2012 08:26 PM
some old fashioned VR parking lot thrashing vividracing Scion FR-S / Toyota 86 GT86 General Forum 8 11-16-2012 02:48 PM
Turbos making less power down low? subatoy Forced Induction 40 10-03-2012 03:30 AM
