Old 08-26-2013, 12:43 PM   #1
jarviz
jarviz's Avatar
Drives: Raven FRS MT
how do you drive in snow.
Definitely in the wrong season, but this random thought popped into my head. If you're on public roads and there's a couple of inches of wet snow on the ground, is it better to leave traction control on or off?
I've had to drive on the highway unfortunately in the middle of the snowstorm, was trying to go uphill when my back end kicked out, but luckily my awesome skills from years of playing gran turismo kicked in, and I counter-steered slightly and remained on the throttle, enough to stay in the lane and make it up the hill. But I'm curious if this would have been more efficient or the car more predictable, with the traction off.
jarviz is offline   Reply With Quote
Old 08-26-2013, 12:44 PM   #2
husker741
Originally Posted by jarviz View Post
how do you drive in the snow.
Sideways.
husker741 is offline   Reply With Quote
The Following 13 Users Say Thank You to husker741 For This Useful Post:
campy (08-26-2013), DarkCard (08-26-2013), davidp (08-27-2013), Enraged21 (08-26-2013), Eurasianman (08-26-2013), FRSBRZGT86FAN (08-27-2013), IntotheOcean (08-26-2013), Jdogg88 (08-27-2013), ohnoimcaught (08-27-2013), pheoxs (08-26-2013), racecaresuaceb (08-26-2013), theurbaninja (08-26-2013), zaptorque (08-26-2013)
Old 08-26-2013, 01:02 PM   #3
thill
With dedicated snow tires and TC on.
The Following 2 Users Say Thank You to thill For This Useful Post:
CBR600RR (08-26-2013), FRyeS (08-26-2013)
Old 08-26-2013, 01:08 PM   #4
wrxgoose
WUB WUB
Drives: 2013 Firestorm
i keep it on, until i get stuck. then i try sport mode. if that doesn't work, then i try TC off. if that doesn't work, i call my friend to help me get her out.
but we don't get much snow here in NC, so i'm not too worried about it
wrxgoose is offline   Reply With Quote
Old 08-26-2013, 01:08 PM   #5
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Good question. I go back and forth on this myself. Last winter I kept the TCS on and it helped prevent the back from coming out from a hill start which was nice but I wonder how it would handle the back end kicking out at speed. Luckily, thanks to my Blizzaks I never got to find that out and hopefully never will.
rapidcars is offline   Reply With Quote
Old 08-26-2013, 01:16 PM   #6
ChristosG
Drives: 2013 Scion FR-S Hot Lava 6MT
I only turned off TC when I got stuck in the snow. Which happened a few times.
ChristosG is offline   Reply With Quote
Old 08-26-2013, 01:23 PM   #7
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I usually drive with TC on, sometimes VSC sport
I had an instance where I was going up a slight hill (was testing out my blizzaks on a side road with a couple inches of snow) and TC was going crazy... One or both wheels started spinning about halfway up the hill, and the TC kicked in, but wheel hop combined with TC trying to compensate for the spin made it feel like the car was going to explode. I quickly turned it off and really had to modulate the throttle the rest of the 100 feet or so. I was going sideways and <5mph at the top of the hill. I barely made it up
Propaganda is offline   Reply With Quote
Old 08-26-2013, 02:04 PM   #8
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I drove around in VSC Sport. Seemed best. Lets a bit of spin happen off the lights and starts but any sliding sideways it kicks then.
Then again the other half the time TC was off and I was sideways on purpose so :shrug:
pheoxs is offline   Reply With Quote
Old 08-26-2013, 02:06 PM   #9
CaptainSlow
CaptainSlow's Avatar
Same way you drive in the sun...only more careful and slower
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 08-26-2013, 02:12 PM   #10
jarviz
jarviz's Avatar
why would turning it off help if you're already stuck. Doesn't the TC give you the traction you need to get out?
Old 08-26-2013, 02:13 PM   #11
jarviz
jarviz's Avatar
Yea but you're tail doesn't kick out unexpectedly when you're under the sun... or at least it shouldn't.
Old 08-26-2013, 02:14 PM   #12
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
I don't use my FRS for the winter, but I generally turn TC off in my accord when there is a lot of snow. Otherwise the TC just kills the motor and wont let it spin the tires to the point that the car wont go anywhere. Sometimes it's beneficial to "burn through" the snow in order to get the car moving/keep it moving. If there isn't a lot of snow, it probably doesn't make a huge difference, assuming you can control the throttle and don't mind going a little sideways every now and then.
FReSh is offline   Reply With Quote
Old 08-26-2013, 02:15 PM   #13
FReSh
Dirt Trackin'
FReSh's Avatar
A lot of car's TC systems will stop the car from spinning the tires almost completely if it is stuck. With it off, you can gun it and try to burn through the snow lol...
Old 08-26-2013, 02:21 PM   #14
SigmaHyperion
Drives: 2013 SWP BRZ Limited
With TC Off, the car will sense a lack of traction and cut power. So it basically won't do anything at all.
You can rock a car loose in the snow, or get up a frozen driveway, or do just about anything in the snow if you KNOW you are going to slip, as long as you have TC off. Leave it on and you'll go nowhere fast.
Traction Control is meant to help you in the case of unexpected slippage. Just like when you go to the track and you turn it off because you know that you're going to be slipping and that's what you want to do, you need to turn it off if you know you are going to be slipping in the snow on purpose.
So keep TC on in the snow, but be prepared to turn it off if it's keeping you from getting good traction from moderate and controlled wheel spin.
SigmaHyperion is offline   Reply With Quote
Anyone drive in the snow yet??? rapidcars NY / NJ / CT / PA 114 01-29-2014 07:42 PM
Snow anyone? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 4 05-11-2013 10:28 AM
This is how you drive a Impreza in the snow wrohdejr Other Vehicles & General Automotive Discussions 3 03-06-2013 11:40 PM
BRZ in snow swift996 BRZ First-Gen (2012+) — General Topics 135 02-10-2013 04:44 PM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 08:30 PM
