Old 08-26-2013, 08:32 AM   #1
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
how do the STI Steering bush compare to whiteline?
How do the STI Steering bushes compare to the whiteline bushes?
ST34112AS000
vs
KSR210
Thanks.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 08-26-2013, 09:09 AM   #2
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
I dont know about either of the brands you mentioned and am very curious of the STi myself
.. but I have perrins aluminum steering rack inserts and love them
why they arent on Perrins site, I dunno,but call and ask- I have two sets of perrins, one in each of our BRZ, they are that good, but its a metal insert, so if youre coming out of a porsche 911 and want that razor sharp think it and it goes steering, the install is cake and its another option aside from two you mentioned.
Huge fan of whiteline too, I would like to see pics of both STI and WL, and can post a pic of what I have if you like
448hpsti is offline   Reply With Quote
Old 08-26-2013, 04:54 PM   #3
DriftEightSix
Pegasus White
Drives: 86
STI
Whiteline
How much noise does the alloy ones make?
I would like to increase the initial turn in feel; i feels its lacking. Whilst it's turned in the car feels amazing; its just that initial turn in that feels off.
Old 08-26-2013, 05:00 PM   #4
OrbitalEllipses
Drives: Attitude
I'd go straight for the Turn in Concepts metal bushings. Easy install, cheap, and I can't discern any difference in NVH.
Old 08-26-2013, 05:11 PM   #5
Hanakuso
Pretty much this. Not really an easy install but not terribly hard with the right tools. I forgot to add grease on mine when I did the install so I might have to go back and do that.
Hanakuso is offline   Reply With Quote
Old 08-26-2013, 05:15 PM   #6
OrbitalEllipses
Drives: Attitude
It's pretty easy. Unbolt the rack, push out the bushing with a 2-jaw puller. Took me an hour plus minor hangups/me being dumb.
Old 08-26-2013, 05:30 PM   #7
Hanakuso
Took me about an hour or more as well. I guess it's easy, just anything more then an oil change isn't easy in my books
Old 08-26-2013, 06:33 PM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I have the TiC alloy bushes installed and can hardly tell any difference over stock either on street or on track.
Old 08-26-2013, 10:08 PM   #9
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Alloy transmits more nvh, below 100 mph ts not noticeable, but as you get well into triple digits the nvh thru steering wheel increases not annoyingly so, but best for track cars and auto x builds more so than a daily driver. I like the feel and feedback of non aluminum for really high speed use, the alloy is almost too responsive and requires more attention
Low speed, especially below 50mph they make turning more precise and add to the experience in a good way
Wife uses her brz for mostly 100 mile commutes each way did try but removed alloy fom her car, it's still on mine, but I'm really eager to try a harder rubber one, but enjoy the easy install of the ones I use, you simply slip them over and sorta into the one ones, remove bolt add insert, revolt, done, but like thy aren't for everybody
kiichiro is offline   Reply With Quote
Old 08-27-2013, 02:01 AM   #10
slava
slava's Avatar
Drives: brZed
got the battle version solid rack bushings. steering feels way better. definitely worth it.
slava is offline   Reply With Quote
Old 08-27-2013, 06:43 PM   #11
DriftEightSix
Pegasus White
Drives: 86
as in noise? or that the part did nothing?
Old 08-27-2013, 07:54 PM   #12
Captain Snooze
Drives: Red Herring
As in I couldn't perceive difference before and after. For me waste of money. Ymmv.
Old 10-22-2013, 10:06 AM   #13
brillo
Drives: 2013 Firestorm FR-S
you might not notice it daily driving now, but you will in a few years when the stock ones would wear down and flex.
I have the TIC bushings and they seem good thus far, not much if any NVH. The only thing I notice is that they are almost to sensitive sometimes at high speed 70+, I feel like the steering reacts to almost any road variation. Its not bad, just can be a little taxing for long driving stints. I have found if I relax my grip on the wheel a bit it counteracts this. I might try the whiteline bushings down the road to see what if any difference I feel as they are so cheap.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS OAKOS Automotive Brakes, Suspension, Chassis 226 01-19-2015 01:46 PM
PST vs DSS carbon driveshafts, anyone compare? OICU812 Engine, Exhaust, Transmission 26 06-15-2014 03:10 PM
David Bush Photo FR-S shots SC David FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 25 07-23-2013 02:47 PM
How does the TRD air filter compare to others BlackyRose Engine, Exhaust, Transmission 0 07-13-2013 06:25 PM
Has anyone installed the whiteline steering rack bushings? was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-18-2013 05:40 PM
