Old 08-24-2013, 04:09 PM   #1
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
SRS light on
Just took my car to a 100% hand wash place. They did the whole 9 yard and the only thing different was that I asked them to clean up a spill of some sort on the passenger side seat. So they did a wet vacuum to get it out. Drove off and now the SRS warning light is on. Could the sensor be that sensitive? I mean we all have problems with leaving our phone charging on the seat and making the seatbelt indicator beep. Is it possible to manually reset or is this a dealer fix? Any help would be appreciated.
Thanks!
Lakers86 is offline   Reply With Quote
Old 08-24-2013, 04:26 PM   #2
BOLT
Drives: FS FT86
Disconnect your negative battery terminal for 3 minutes, connect it and see if the MIL/SRS light goes away
BOLT is offline   Reply With Quote
The Following User Says Thank You to BOLT For This Useful Post:
Lakers86 (08-24-2013)
Old 08-24-2013, 04:51 PM   #3
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Hopefully there's nothing srs-ly wrong with it.
campy is offline   Reply With Quote
The Following 3 Users Say Thank You to campy For This Useful Post:
Anthony (08-26-2013), humfrz (08-25-2013), MikesFRS (08-26-2013)
Old 08-24-2013, 04:57 PM   #4
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
Ill try that once I get back home.. Well see what happens
Old 08-24-2013, 04:57 PM   #5
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
Hahaha good one man.. Lol
Old 08-25-2013, 05:04 PM   #6
Fluxx
Drives: 2013 FR-S in Ultramarine
They are that sensitive, at least mine is. If I set a 1 liter bottled water on the seat it will trip the sensor and beep like crazy at me.
Fluxx is offline   Reply With Quote
Old 08-25-2013, 06:21 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Or disconnect and step on the brakes for 3-5 seconds to get a full drain. Should reset it and then just wait n see if it returns
Old 08-25-2013, 07:47 PM   #8
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
apparently these sensors don't like water. if it does not turn off after the rest, blow dry your set and that may work.
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 08-25-2013, 08:24 PM   #9
chriscross_tnt
chriscross_tnt's Avatar
Drives: 02 maxima 6spd sold 2013 frs daily
Wouldnt this be a warranty claim issue? The dealer will have all the necessary resources too figure out whats going on.
chriscross_tnt is offline   Reply With Quote
Old 08-25-2013, 08:34 PM   #10
DarkCard
Drives: Asphalt Scion Frs 6MT
da-dum, tssss
DarkCard is offline   Reply With Quote
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 11:25 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 08:26 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 01:14 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 12:21 PM
