Old 08-17-2013, 06:54 AM   #1
pinaygirlcassy
pinaygirlcassy's Avatar
Drives: Scion FR-S
need help guys :(
I bought some new shoes for my car today and the size is 18x8.5 +35 but the problem is that the bolt pattern is 5x112 :/ i really want to keep them but is there any way i can mount these on safely?
I got them for a steal so i couldnt resist lol.
sorry if someone answered this already i just didnt seem to find a topic about it :/
Instagram: pinaygirlcassy
pinaygirlcassy is offline   Reply With Quote
Old 08-17-2013, 07:12 AM   #2
Foobar
SLO NO MO
Foobar's Avatar
You'll need something like this http://www.motorcitybolton.com/5x110...-adapters.html
These adapters add at least 20mm thickness to your offset so if you wheels already poke, they'll poke even more.
Sent from my Nexus 4 using Tapatalk 4
Old 08-17-2013, 07:40 AM   #3
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Yeah 20mm will be good with DD don't know about track use on how they would hold up. What wheels did you get your hands on if you don't mind me asking?
Ny Brz is offline   Reply With Quote
Old 08-17-2013, 09:33 AM   #4
infinite012
Drives: 13 DGM BRZ Ltd
Except the adapters you linked to are the wrong bolt pattern. 5x100 to 5x112 is what she needs.
But really, pushing a +35mm wheel out 20mm more will turn it into a +15 wheel. In order to fit in, you will need to slam the car on the frame and have at least 30 degrees of negative camber so you can eat through your 195 width stretched tires.
Don't run wheels that weren't originally meant to be run on your bolt pattern until you really understand what needs to happen to do it.
infinite012 is offline   Reply With Quote
Old 08-17-2013, 10:28 AM   #5
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
It will be less of a headache to just sell them honestly
ihaskrayon is offline   Reply With Quote
Old 08-17-2013, 10:44 AM   #6
Suberman
Drives: Subaru BRZ Sport Tech Satin White
5x100 is the bolt circle for Subaru and small Toyotas.
Suberman is offline   Reply With Quote
Old 08-17-2013, 12:19 PM   #7
pinaygirlcassy
Drives: Scion FR-S
theyre bbs lm reps lol i got them for 300 with tires so it was a steal aha. I wish i could afford the real deal but i only work part time as a waitress
Old 08-17-2013, 12:21 PM   #8
pinaygirlcassy
Drives: Scion FR-S
ill probably put them up for trade/sale then cuz honestly i think thatll be the easiest solution...thanks for the advice guys
Old 08-17-2013, 12:47 PM   #9
ihaskrayon
The Comedian
I think 5x112 is the bolt pattern for VW. I'm not 100% sure, but chances are, you can sell them for more than you paid for on a GTI forum. Make a quick profit and sell them for $500 :happy0180:
Old 08-17-2013, 01:18 PM   #10
86Toyobaru
Drives: 86 & GRB
18x8.5 +35 5HX112
The first thing you need to check is the back of your rim. Make sure its has hole to let stock stud to pass through, if you are going to use PCD changer.
The stock stud is 24mm long. The PCD changer is usually at least 15mm thickness.
So your new rim will need at least 9mm depth of hole on its back side of hub. BTW, the +20 offset is going to be ugly on our car.
86Toyobaru is offline   Reply With Quote
Old 08-17-2013, 02:35 PM   #11
KONVERTER
KONVERTER's Avatar
20mm adapters will add to much poke.
You will need to get new wheel hubs. (About $800 plus labor).
KONVERTER is offline   Reply With Quote
Old 08-17-2013, 09:39 PM   #12
mswhong
Only option is to get 20mm adapters - that'll make ur offset to +15
IMHO, sell the rim/tyre combo and try to make some profit!
mswhong is offline   Reply With Quote
Old 08-20-2013, 09:27 AM   #13
n2oinferno
Praise Helix!
n2oinferno's Avatar
Sell them. I hate to sound like a ****, but it's not a steal when they don't fit.
Old 08-20-2013, 12:51 PM   #14
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
no way lol!!! It can be easily converted to 5x100. Add some negative chambers to reduce the poke. I'm assuming you are on coils.
They are safe. No worries.
Or you could listen to others. Sell them for profit, then buy similar shoes which don't require converter.
hanabie is offline   Reply With Quote
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
Used BRZ, what do you guys think? Turbowned New England 36 05-23-2013 03:07 PM
what do you guys think? Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 19 05-20-2013 04:09 PM
oh, hey guys NESW20 Other Vehicles & General Automotive Discussions 26 01-22-2012 11:30 PM
What do you guys think?? Arcangel Scion FR-S / Toyota 86 GT86 General Forum 19 10-30-2009 11:06 AM
